It is currently Sun Jun 07, 2026 1:17 pm
 Post subject: weber or something else
PostPosted: Sun Apr 20, 2014 1:02 pm
after doing the tune up to my 74 luv this weekend. I've decided to upgrade my carburetor but quite not sure what to go with could someone please lead me in the right direction which modelto go with with my stock 74 Luv. I removed the sMog stuff. any suggestions are appreciated thanks Guys.
PostPosted: Sun Apr 20, 2014 4:36 pm
weber 32/36 dgev if you want electric choke. there is a kit to adapt it to a stock intake.
there is also a mechanical choke and a temperature activated choke option
PostPosted: Sun Apr 20, 2014 9:03 pm
What do u mean by electric choke
PostPosted: Sun Apr 20, 2014 10:04 pm
Choke hooks up to key on power and after a bit the coil heats up enough to open if fully.
PostPosted: Mon Apr 21, 2014 7:51 am
Ok so ive decided to go with the carburetor with the electric choke I found it on redline Weber but I didn't see the adoption kit.
PostPosted: Mon Apr 21, 2014 7:52 am
By this do you mean just run a hot wire to the battery??? :roll:
PostPosted: Mon Apr 21, 2014 11:09 am
Key on power is not battery power...
PostPosted: Mon Apr 21, 2014 12:13 pm
Thats why im asking What he meant by key on. can someone post a pic of were this wire would go??
PostPosted: Mon Apr 21, 2014 1:57 pm
Hook it to the same wire that powers the electronic choke on your stock carb. There are only a couple wires hooked to the carb, us the one that has power when the key is on.
PostPosted: Mon Apr 21, 2014 2:29 pm
He might have a manual choke on his carb now. The easy way is to make a wire from the coil with a 3 amp or so fuse in line.
EDIT. Scratch what I said, the wiring schematic shows a 74 does have a electric choke. Like what was said before, wire it up like the old carb. Before you do any work on this truck get a manual, sounds like you might need one.
PostPosted: Sun Apr 27, 2014 9:31 pm
Check it out
File comment: this is the electric choke right.
Check it out
PostPosted: Sun Apr 27, 2014 9:38 pm
Looks like a manual choke. Wire up the new card as what was mentioned above.
PostPosted: Sun Apr 27, 2014 10:36 pm
So that wire in the pic isnt the electronic choke
PostPosted: Mon Apr 28, 2014 8:58 am
I have no idea what you just said.
I might have figured out what you are asking. All of them is the correct answer.
