It is currently Thu Mar 26, 2026 11:20 am
PostPosted: Mon Dec 22, 2003 10:30 am
Can someone with a front disc brake set up please make me a template of the bracket that the caliper bolts to so I can have some made. Havent had luck finding any to convert my 75 so I ll have to get my co worker to make them. He did a set for his s-10 rock crawler and his new buggy crawler but he had to have something to go by. Thanks for any help.
 Post subject: Template
PostPosted: Mon Dec 22, 2003 1:04 pm
As mine are currently sitting on the shelf waiting for eventual assembly, I can make templates and take some measurements for you with little trouble. I will be in the garage tomorrow evening and will start then, if nobody else responds.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Dec 22, 2003 7:29 pm
im doing a toyota solid front end but that wont be for a while so if u want to wait u might be able to get them matt
PostPosted: Mon Dec 22, 2003 9:58 pm
I think the 4wd ones are different than the 2wd ones. Thanks for that offer though. Mines a 2wd. Guess I shouldve mentioned that.
 Post subject: brakes
PostPosted: Tue Dec 23, 2003 1:25 pm
I will go ahead and make the templates and take the measurements this week for you.
Rick
Loranger, La
PostPosted: Tue Dec 23, 2003 10:40 pm
Hey Bighappy I have a 75 with the disc conversion done to it, mine is a 2wd as well...... my question is what are you trying to do? Are you just wanting to just do a disc conversion? Are you looking to get your discs from another luv or are you looking at something different to get your discs from? I was just wondering, I mean if you can find a donor 78 everything just swaps right out! Fortunately I found one member who had an extra front end from a 78 he didnt need so I got the whole front end and swapped it out. It took about four hours from start to finish. Well just my two pennies!
Later
Husker
PostPosted: Wed Dec 24, 2003 10:55 am
I would LOVE to get a donor truck, but I live in IL, and apparently Luvs are like dinos here. Ive called every yard around, done a parts search on different sites, posted two posts here and havent found dick. I started searching for the stuff last spring when I bought the truck. So if I have to have them made so be it. The brackets my freind has made fit perfectly on his rigs, so I know he can do it. I just need the specs or templates. Hell, if hes up for it, I ll see if he would make a bunch and spread the wealth.
PostPosted: Wed Dec 24, 2003 10:58 am
Thanks Rick! you need anything for your truck? I took some stuff off mine that Im not reusing.
 Post subject: template
PostPosted: Wed Dec 24, 2003 12:45 pm
No problem, but a front valence (the large one ) would be nice! :wink: :wink: Will let you know ehn they are done.
Rick
Loranger, La
PostPosted: Sat Dec 27, 2003 12:47 pm
My front valance was cut in half with a torch and missing a two foot wide section down the middle 8O
 Post subject: Valance
PostPosted: Sat Dec 27, 2003 9:20 pm
Oh well.
I have traced the templates and will also send some pictures to better show just how they look.
Rick
Loranger, La
PostPosted: Sun Dec 28, 2003 3:07 pm
Thanks. Check your pm.
PostPosted: Sun Jan 04, 2004 8:40 am
theres a junk yard in paris tn that 2 two wheel drives and 1 four wheel drive shady grove auto salvage(731) 642-8952 just in case someone is near.he is crushing but with all the rain he wont let the crushers out in the field.
PostPosted: Thu Jan 08, 2004 12:55 am
Has anyone ever looked in to swapping spindels to something like pinto there all disk front ends And we use pinto spindels on our modified stock car so i know there strong enough and the make a bracket you can bye at the race shops to mount 10" GM disks and calipers to them .................and thats my two cents
