It is currently Sun Jun 07, 2026 5:15 am
 Post subject: Lights don't work
PostPosted: Tue Apr 01, 2014 5:08 pm
I have a problem with lights not on my luv, but on a 61 Mercedes. The front parking lamp is an 1157 bulb with two contacts on the base. The blinker is the other contact and it works. When I use my meter, I can pull 12 V off the contact for the parking lamp circuit, but the bulb still won't light up. I tried a brand new bulb because my luv uses the same one and I had one of the pair laying around.
I think I just need to clean it somehow. I sprayed QD electronics contact cleaner in there. Is there another good way to clean contacts deep in the socket?
Thanks
 Post subject: Re: Lights don't work
PostPosted: Tue Apr 01, 2014 10:44 pm
Green scrub pad tightly rolled up & twisted back & forth?
PostPosted: Sat Apr 05, 2014 2:49 am
It doesn't use an 1157 bulb. Most German autos use a 5489? The number escapes me but the contacts on the base are different looking. A 1157 will fit , but won't work because the contacts are different.
while the pessimist and optimist were arguing about the glass of water, the opportunist drank it.
PostPosted: Mon Apr 07, 2014 11:45 am
The one in the tail light is different. Maybe the front is the wrong bulb.
Thanks
Users browsing this forum: Bing [Bot] and 34 guests
