It is currently Thu Jul 16, 2026 5:50 pm
Post new topic Reply to topic  [ 217 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
 Post subject: Re: my 78 luv build
PostPosted: Fri Mar 07, 2014 8:56 am
Should feel the torque converter go in 3 times before it 'seats' correctly. Push against it with one hand while spinning it clockwise. Be patient, it sometimes takes several revolutions before you will fell it go it, and it will be slightly more 'difficult' as you go. You will still see a slight amount of the neck of the converter showing, but not a lot of it. Do NOT try to force it on by trying to pull the trans up to the block with the bellhousing bolts...
PostPosted: Fri Mar 07, 2014 9:10 am
Thanks, that's good to know.
PostPosted: Fri Mar 07, 2014 2:54 pm
Definetly isn't seating all the way. It only sucks into the bellhousing like 1/4". Problem is its not sliding onto the 2 oil pump keys
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Fri Mar 07, 2014 10:52 pm
I think Mytmouz was saying to keep pushing the transmission while you turn the torque converter clockwise. Was the combination you have, working together as a unit before?
PostPosted: Tue Mar 11, 2014 2:45 pm
Welded up the mounts today, gonna do radiator next. And have to clearenxe the front frame xmember for pulleys. Also my tq. Converter is too short. That's why it wasn't going on all the way lol
I'm workin' on it
SBC
PostPosted: Tue Mar 11, 2014 4:53 pm
Motor and tranny are in, hei pulleys, everything cles. But the Tranny dipstick. Too bad I have to pull it out again to put the pan gasket and a new tq. Converter in, along with the gear drive. Also, my stock driveline is perfect. Bolted it up today and it doesn't need to be shortened/lengthened at all. Still need parts to make the motor run, fuel pump, plug wires alternator and a short water pump. Belts hoses more fluids and the right torque converter. Almost there....
I'm workin' on it
SBC
PostPosted: Thu Mar 13, 2014 10:44 am
quick shot of the engine bay. yes I know my valve covers are backwards :D
I'm workin' on it
SBC
PostPosted: Thu Mar 13, 2014 10:49 am
interior shot. keep going back and forth on those rx7 seats or my factory Mikado seats.
I'm workin' on it
SBC
PostPosted: Thu Mar 13, 2014 7:34 pm
Lookin good man! Those seats fit in there a lot nicer than mine do!
PostPosted: Mon Mar 17, 2014 12:52 pm
rx7 or Mikado seats? the Mikado seats will bolt right up and are very comfortable, but have some rips and tears... rx7 seats match the door panels, keep you in the seat but are no where near close to bolting up and sit really low, but I can make brackets. what do you guys think?
I'm workin' on it
SBC
PostPosted: Mon Mar 17, 2014 1:15 pm
I peraonally like the tan ones but making rails is a pita. The head rests on your mikado seats are different than mine were i think. Mine was all one piece the headrest didnt move.
Hows the rest of the build comin?
PostPosted: Mon Mar 17, 2014 2:51 pm
I'm leaning towards the tan seats also... It's getting there slowly but surely. Lately I've Been trying to find a torque converter that'll work. Then its just the little things for the motor to run, exhaust, and figure out a throttle cable/linkage setup. I also still need to get a swp pulley and I'm sure I'm forgetting stuff lol
I'm workin' on it
SBC
PostPosted: Fri Mar 28, 2014 3:37 am
very nice! i love the sound of a nice gear drive whirring away
im at the tying up loose ends stage as well
PostPosted: Tue Apr 01, 2014 1:12 pm
Not a lot goin on lately, building a house and have a ford in the luvs house at the moment. Can't decide if I should do an electric water pump or a normal belt driven one. I'll probably do a normal one and use the money saved on other things
I'm workin' on it
SBC
PostPosted: Tue Apr 01, 2014 4:15 pm
i have no experience with electric pumps but i have been told they are more for race applications than a street rig
i would feel more secure with a belt driven pump that cant blow a fuse without my knowledge that is just my opinion tho
however you go with it im ready to see your rig running! so many of us at the 90% mark right now
PostPosted: Tue Apr 01, 2014 4:34 pm
A Corvette water pump is what a lot of guys are using for the clearance issues. There are some articles on here that detail the whole process.
PostPosted: Tue Apr 01, 2014 8:36 pm
I'm thinking a belt driven one will go on. And I'm ready for it to be running too! Haven't drove it since august 1st. I can't wait to fire up this beast, drive it and actually be able to break the tires loose :)
I'm workin' on it
SBC
PostPosted: Wed Apr 02, 2014 5:10 am
Yep. I used to love driving mine. More fun than, well, almost anything else.
PostPosted: Wed Apr 02, 2014 2:25 pm
I liked driving it with the 4 banger, I'm thinking the v8 will make it a bit more fun :)
I'm workin' on it
SBC
PostPosted: Wed Apr 02, 2014 2:38 pm
maybe just a little more fun lol
they are a lot of fun to drive even when they are really slow. they just have a character to them
