It is currently Mon May 25, 2026 6:01 am
PostPosted: Thu Mar 13, 2014 3:40 pm
My leaf springs are ruined and CANNOT be measured. Does anyone know the measurements for the leaf springs on a 2wd 74 Luv?
PostPosted: Thu Mar 13, 2014 3:58 pm
I have my original 72 stock springs stashed away. I will get them out and measure them. What exactly do you need, overall length, eyelet to eyelet ect?
PostPosted: Thu Mar 13, 2014 4:07 pm
From the parts book, 78-80 2wd are the same part number. 94027504. 76 part number is 94026218, 75 is 94025087, no part numbers shown for 72-74. The book does not show measurements but put up part numbers in hopes it helps.
PostPosted: Thu Mar 13, 2014 4:47 pm
Luvtruck.com lifer...
Here is a link to what Calvert tells me that I need. http://www.calvertracing.com/documents/CalTracsDimension-truck.pdf
Can you help me?
There is no one locally that even has a used Luv that I can go measure.
Thanks,
PostPosted: Thu Mar 13, 2014 10:10 pm
Here is what I came up with. On the original Calvert form their diagram shows the axle under the spring. On a Luv the axle is over so I measured over the leaf. My measurements were from 1972 springs. I do know that the 76 springs I have on now use different size bushings and bolts than the earlier trucks.
PostPosted: Fri Mar 14, 2014 1:04 am
Thanks for the measurements!
PostPosted: Fri Mar 14, 2014 10:25 am
HotRod80 said that Calvert has the measurements. I would hope they can confirm what I measured just to be safe.
PostPosted: Fri Mar 14, 2014 11:32 am
There are differences between the years for sure , but the Split monos can be made to work . The later models have the larger pin with the nut on the back similar to a Nissan hard body . I filed in the hole with metal cut with a hole saw and welded it into the front mount to used a standard bolt . I also narrowed the fronts of a set of Calvert springs to 2.25" and had custom bushings made to use the factory pins . I repeat the best way to do the swap is to buy the Afco front perches , mark the factory front pin location and cut and weld the Afcos in place of the factory ones and you are done . If you cant do this find a reputable race car chassis shop to do it . Or square everything with a long piece of all thread with nuts and washers . Make sure your spring rate is good for your use . I think they offer 200 and 225 . Use 225 if you ever plan to use it as a truck .
