It is currently Sun May 31, 2026 1:25 am
PostPosted: Sat Feb 22, 2014 10:25 pm
The subject line pretty much says it all.
I am still trying to find a Dome light for my Luv (I think we all are)
Just want to know if the Larger Mikado unit screws in with the same mounting as the smaller standard dome light?
Nicko
PostPosted: Wed Feb 26, 2014 8:36 pm
anyone?
PostPosted: Wed Feb 26, 2014 8:43 pm
I'll check tonight and update this post.
PostPosted: Wed Feb 26, 2014 9:22 pm
Legend! thanks mate.
PostPosted: Wed Feb 26, 2014 10:54 pm
I got tired of trying to find a light in good condition. I got a light from a Mitsubishi Mighty Max and it screwed right in.
PostPosted: Sun Mar 02, 2014 9:02 pm
Did you get a chance to have a look mate?
PostPosted: Mon Mar 03, 2014 3:28 am
Luvrv8 what is a mitsubishi mighty max? we may have a similar mitsi model here we can pinch the light from?
never mind i googled it! (should have done that to start with!) down here there a mitsubishi triton,might head out to my mates triton and try his light!
1976 Luv
1980 Isuzu kb 4x4
Nissan GU Patrol
Ford Falcon AU ute
PostPosted: Mon Mar 03, 2014 5:18 am
If you have a win mrfibbles let me know what year fits!
PostPosted: Tue Mar 04, 2014 8:53 pm
Yep, thanks for the patience, I'm just slower than I thought I'd be. Here are some photos of the Mikado style light / dome lamp, and its mount configuration.
PostPosted: Tue Mar 04, 2014 11:39 pm
Thanks mate!
Looks like the Mikado has an offset mounting hole on the one side to allow for the switch.
I found a NOS light, looks like there is enough meat on the mounting plate to redrill for the Mikado light so I bought it.
Wasnt cheap but its in the origional package and box!
Nick
PostPosted: Wed Mar 05, 2014 6:56 pm
Keep in mind that the hole also appears to function as a ground. Presumably, you'll be handling grounding some other way, since the metal clip won't be the same there.
PostPosted: Thu Mar 06, 2014 5:53 am
The ground should still work the same way as the screw will earth to the metal mounting.
Users browsing this forum: Google [Bot] and 38 guests
