It is currently Mon May 11, 2026 10:10 am
 Post subject: Trooper owners...
PostPosted: Wed Nov 26, 2003 4:26 am
How many of us are on here? i wonder if theres enough to get a trooper forum added :lol:
PostPosted: Wed Nov 26, 2003 10:56 am
You can count me in to.
PostPosted: Wed Nov 26, 2003 4:11 pm
alright i know theres more than this, where Kuranosuke at? :?
 Post subject: Just got one
PostPosted: Sun Dec 07, 2003 6:04 pm
I just got one that I'm going to get running and sell, cheap! It has a messed up piston from a broken valve and a replacement head. I may have the replacement piston, but I'm not 100% sure at this time.
-DK
PostPosted: Sun Dec 07, 2003 6:33 pm
Resident Sparktrician
I'm here, man! I'm here! :P
I'm seriously considering a swap to a 3.4L in mine so I can push those future 33s that are going to go on it.
Speaking of that, I'm looking for a rebuildable 3.4L block. Anyone?
Dkay: Please inform me of this Trooper you have, and that will be going for 'cheap'. Drivetrain, trim, etc. info would be highly useful...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Mon Dec 08, 2003 2:22 am
hosetly, i would be warry of the early isuzu v-6s. They have issues whith oil consumption. The rings dont seat right and some passeges plug up easilly and isuzu has said that 1qt per 1000 miles is normal(no i didnt mean 3000miles i mean 1000miles). SO if you do do this, keep a close eye on your oil situation, and be shure to have the block cleaned vary well. They make good power and everything they just go through oil.
PostPosted: Mon Dec 08, 2003 9:11 am
This isn't an Isuzu motor. This is the GM motor that went into Camaros and Firebirds. Little torque houses. There is also the Crate version that went into the S-10 and Blazer. I'm looking forward to this one. It'll either be 3.4 or the later 3.2L Isuzu V-6.
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Thu Jan 01, 2004 10:37 am
Just got a trooper too its a 1992 2.8TD this is what l have planed for it lm going to scrap the body and put a LUV CAB on the chasiss.
PostPosted: Sat Jan 03, 2004 1:36 am
86 2 door 2.3L 5 Spd Trooper (not a II) here. I'm looking to pick up another a bit newer, 90 or 91 (still 1st gen) for a daily driver and then turn this one into more of a 'Ute for work/play. For a 4x LUV owner, a Trooper really seems like a logical next step to take. They can get a ton of groceries in the rain and if anything ever happens to it, you can pull parts off to improve your LUV.
I just had the pleasure of driving over Nestucca in a foot of snow in the trooper and it did great. I have to say though, the stock size 15 inch passenger car radials that came on it must go. I would have taken my 2WD LUV through that snow no problem on the Wildcat LT tires it has on it, but the Trooper needed every bit of the 4WD turning with the whitewalled grampa tires the previous owner put on it.
PostPosted: Sat Jan 03, 2004 4:23 am
sc010b7527: If you're ever over on this side of the lake, why don't you throw one of those 2.8TDs in your suitcase for me? Damn, I wish we could get those here.
800xl: Go down to Firestone and pick up some Dueller A/Ts in the 31x10.50 flavor. That's what I did and they got me home from Portland the other night after they cancelled that lame-assed "chains only" crap. I love them, and if you catch the timing right, you can get them on a buy 3 get 1 free deal like I did...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Sat Jan 03, 2004 12:30 pm
ye 2.8TD is great lm thinking of putting one in my 4x2 LUV too.
PostPosted: Sat Jan 03, 2004 12:42 pm
If it were just tires I'd probably do it this month, but I have other stuff to catch as well. It needs wheels, and I need to replace 3 broken studs on the front. I'm not going anywhere near a tire dealer until those studs get replaced. I just know they'd crack a couple more off and I'd be stuck paying them to fix it. (can't be our fault sir, three were already broke) The thing also needs an alignment but the same reasoning holds there.
PostPosted: Sat Jan 03, 2004 1:14 pm
Yeah, I understand. I got the rears replaced when I got the brake job done. I'm still working on the front. Just replace them all, man. The lugs and studs both need to go as they are very soft and strip/break very easily. At Firestone, I bought the lifetime alignment and all four tires with lifetime balance, rotation, and flat repair for right around $500 out the door. Good Luck!
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Tue Jan 06, 2004 11:58 pm
My freind and i are rebuilding an 89 trooper we got for 400. i heard they flip pretty easy tho so we are welding a rollcage for the cab.
PostPosted: Tue Jul 20, 2004 9:42 am
I've got a 96 trooper its a piece of shit. It worked good when I got it. But after I had it for a month i got into a head on collision. It never worked the same after that. But I think it will be a good thing if we get a trooper form added
PostPosted: Fri Aug 27, 2004 1:02 pm
Banishment Pending
If you guys start a Trooper forum count me in, i got a 1988 w/ 2.6 and a 5 speed, bone stork with the exceptions of Michlin LTX A/T's in the 235x75r15 flavor, great tires, thing will go places i wouldn't want to take a Wrangler or a CJ 5 or 7, and a Yakima roof rack :lol:
