It is currently Mon May 11, 2026 2:30 am
PostPosted: Fri Feb 14, 2014 2:57 am
Hi guys.
I have a 74 2wd luv which is geared extremely low.
Were there different diff ratio options for these trucks?
Can I buy something new to increase the ratios or can I use a diff center from an Isuzu kb20?
If so what am I looking for?
Nick
PostPosted: Fri Feb 14, 2014 9:39 am
Early LUVs came with 4.56 gears, the rear end is a corporate Isuzu 10-bolt & was used in various Isuzu vehicles in various ratios here in the US, probably the same where you live.
Different gear ratios available are 4.78, 4.56, 4.30, 4.10, 3.90, 3.73 & 3.42.
The 3rd member with a suitable ratio should interchange.
For the 3.73 & 3.42 ratios look first to diesel powered vehicles.
PostPosted: Fri Feb 14, 2014 9:41 am
Nick, what country are you in?
PostPosted: Fri Feb 14, 2014 1:22 pm
Australia if i remember right
PostPosted: Fri Feb 14, 2014 1:26 pm
I suspected he wasn't from the US. He may have other options than what we have here.
PostPosted: Fri Feb 14, 2014 9:57 pm
Australian LUV Guru
5.125:1 found in early Luvs
4.555:1 found in Petrol/Diesel Luvs/KB petrol and diesel Holden Jackaroo early yrs LSD
4.11:1 found in 2wd Kb Rodeos
3.90:1 found in early Holden Piazza/Isuzu Impulse LSD bolt in fit
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Feb 14, 2014 10:05 pm
Wow they were built for work down there o.O those are some crawling ratios
PostPosted: Sat Feb 15, 2014 1:37 am
Excellent information!
Thankyou everyone. And yes I am in Australia.
I shall start searching!
PostPosted: Sat Feb 15, 2014 1:54 am
So just to confirm ozluvtrucker, if I find one of those vehicles at a wreckers, I can pull the diff internals and they will bolt straight into the luv housing?
PostPosted: Sat Feb 15, 2014 4:05 am
Australian LUV Guru
Yes, all KB rodeos either 2wd or 4x4 will have either a 4.11 or 4.55 that will bolt into your Luv housing, also early Holden Jackaroo's up untill 86 when they changed from a 10bolt rear to a 12 will also bolt in you will only find 4.55 either open or LSD.
Early Holden Piazza will fit also (im unsure of yrs very short run i hear) will fit and you will most likely find 3.90 LSD.
Good luck finding 4.11, i have been searching for a front and rear for my KB but no luck yet, i have been lucky and found a few 4.55 LSD and 1 rare 3.90 LSD
PostPosted: Sun Feb 16, 2014 5:57 am
The search begins!
PostPosted: Tue Mar 18, 2014 11:57 am
Is there a way to tell what diff is what for us that dont know. Is there a tag or marking on the housing itself
PostPosted: Sat Mar 22, 2014 4:11 am
Are all the luv and kb 25 the same ratio? I have a kb25 diff out of my 80 mod if it's any different to what you already have, just sitting in the shed since I've done my new rear end.I'm in tassie.
PostPosted: Sat Mar 22, 2014 10:43 pm
Looks like I have found a KB20 center. Just waiting on delivery :)
PostPosted: Sat Mar 22, 2014 11:50 pm
Good info OzLuvTrucker, looks like I am up for a Diff center hunt. 8O
Josh
