It is currently Sun Jun 07, 2026 12:17 pm
 Post subject: Electronic distributor
PostPosted: Sat Feb 01, 2014 3:40 pm
I know in the past I have come across the how-to on the points to electronic distributor conversion but I can't find it again. I've played with the search quite a bit but am not finding it. My main question is what wires connect and where. I remember it being + and - to the coil. Is this correct? I know it was really simple but can't find the thread.
PostPosted: Sat Feb 01, 2014 4:44 pm
http://www.luvtruck.com/Information.htm
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Sat Feb 01, 2014 5:07 pm
I used a 1985 isuzu pickup 1.9 distributor its a direct drop in and electronic, one two + and one to - on the coil and its good to go
There is also the pertronix ignition coversion on the stock dizzy that is generally cheaper, you can find a used pup distributor and drop it in
PostPosted: Mon Feb 03, 2014 7:35 pm
If you have not obtained a distributor yet, I recommend going with the newer Isuzu ones with the internal module. Simpler setup and one less thing to have to find a place to mount.
