It is currently Thu Jul 02, 2026 4:25 am
 Post subject: ?4.3? Chevy Block ID
PostPosted: Thu Jan 23, 2014 3:57 pm
The 1.8 recently blew in the luv and my uncle gave me a ?4.3 v6? the only thing is i cant find any info on the year. I have the Block numbers that are stamped on the Water pump inlet which are CGB172436 with T0334ubc above it. Do i have the right numbers to find out which year it is? if so, hwat year is it?
 Post subject: Re: ?4.3? Chevy Block ID
PostPosted: Thu Jan 23, 2014 4:39 pm
I've never done extensive research on 4.3 casting #s even though I have several trucks and a boat with 4.3s. The way I always tell is by the valve covers, timing covers, and intake manifolds.
Post a pic and I can tell you which motor you have.
PostPosted: Thu Jan 23, 2014 5:00 pm
Take a look here http://www.s10forum.com/forum/f107/the- ... fo-131868/
Here is the actual magazine post.
http://www.enginebuildermag.com/2000/04 ... chevy-262/
Its from 2000 so, the images dont load.. The info is there. :D
PostPosted: Fri Jan 24, 2014 5:46 pm
I dont have any pictures at the moment. Its locked in the shop at my college. I do however have all the numbers i could find located on the block. On the water pump inlet there are two numbers, T0224ubc and CGB172436. On the bell housing the numbers are 14088553. It is a 4.3?LG?
