It is currently Sun Feb 01, 2026 6:33 pm
Post new topic Reply to topic  [ 189 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Sat Nov 02, 2013 1:07 pm
Now THAT would be a sweet setup. Keeping 4wd really limits my handling mods :evil: corvette or supra irs setups seem to be popular in minitrucks. Drift sessions in the future?
PostPosted: Mon Nov 11, 2013 11:25 pm
Cut out the motor mounts today. Have been thinking about it since I put them in a wile back. Going to make a one piece mount instead of a three pieces welded together. For a cleaner look and stronger mount. I was never really happy with the ones I put in before. Sorry no pics of the mangled mess. I will post some when I get the new mounts though.
My names Trevor BTW. ;)
PostPosted: Tue Nov 12, 2013 2:01 pm
sweet deal dude what are you going to use for the new ones square steel tube?
I was also wondering what your plans are for the engine in the future are you planning to keep it mostly stock or have the housings ported, turbo/injector upgrades etc? im doubting it will need much more power than it already has but go big seems to be a common theme around the forum :lol: and with IRS you would have a hell of a good time with a rotary powered luv 8)
PostPosted: Wed Nov 13, 2013 8:31 pm
The same design as what I took out, but a single piece instead of three pieces welded together. Mostly stock for now, unless I come into some money, but then again if I came into some money I would just drop the 20b 3 rotor in :). Once it's time to rebuild I think I'll go pp and single turbo.
PostPosted: Thu Nov 14, 2013 12:57 am
shooooot a 20b would be outrageous :lol:
they have a 6 speed that will go behind those don't they? i would kill for a vette 6 speed for mine just to say its a 6 speed :lol:
PostPosted: Thu Nov 14, 2013 8:42 pm
One gear for every cylinder. haha.
PostPosted: Thu Nov 14, 2013 8:50 pm
Or in your case one for every compression chamber :lol:
PostPosted: Tue Nov 26, 2013 10:56 pm
Picked up the the new motor mounts today. Going to try and get them in this weekend. Way more happy with a single piece mount, they just look more sturdy. Really glad I decided to change them.
Will try and get some pictures up tomorrow.
PostPosted: Thu Nov 28, 2013 11:05 pm
PostPosted: Thu Dec 05, 2013 10:56 pm
Got the new ones 80% welded in today.
PostPosted: Fri Dec 06, 2013 3:01 pm
man those look great! I cant wait to see this thing running and driving! one of these days when all these local builds are done we all need to get together for a meet. seems to have been talked about 10+ times but hasn't happened, maybe in spring
what are you planning for the interior?
PostPosted: Fri Dec 06, 2013 7:32 pm
Ya, a LUV meet would be cool.
Going to do some bucket seats, probably from a bronco II. I f I could get the ones from the RX8 for cheap I'll do that.
Redo the dash with hard foam and cloth wrap, redo the door panels to match.
Full carpet and headliner.
nice sound system, nothing overly outrageous, just quality sound and decent sound level. To go with that, I will also be sound deadening the entire cab interior, Floor, roof, firewall, back of cab (under the window), and inside the doors.
electric window conversion as well.
Ohh! and cup holders, HAVE! to have cup holders.
I'm sure that I am missing some thing, but you get the idea. ;)
PostPosted: Fri Dec 06, 2013 9:31 pm
Thats gonna be nice! Im trying to plan out a console just so i can get cup holders
I got some pretty nice seats from a newer volvo for a screamin deal.
PostPosted: Sat Jan 18, 2014 1:00 am
Small update.
Added a small piece to the top of motor mount. For a little added strength and visual appeal. I have cleaned up the welds, filled some of the holes that appeared after removing the slag and smoke after this photo was taken. Also filled the larger holes next to the mounts.
Working on relocating the stut rods from the front of the lower control arm to the back side of it.
Before I plated the control arm to make a mounting point.
And after.
Had some tubing bent at a local fab shop.
I cut it to length and fitment for my application.
Tacked in place to check clearance to the frame.
PostPosted: Mon Jan 20, 2014 12:34 am
Welded in place. Working on the brackets to mount it to the frame.
PostPosted: Mon Jan 20, 2014 12:57 am
Nice welds..
PostPosted: Mon Jan 20, 2014 1:18 am
Diabolical wrote:
Nice welds..
Thank you.
I've seen my welding skill increase as this project has gone on and have figured out the little quirks with this Eastwood welder.
PostPosted: Tue Jan 21, 2014 10:27 pm
well I had planned on posting some pics of the finished strut rods but this happened.
never thought it would happen to me. Haha.
PostPosted: Tue Jan 21, 2014 10:55 pm
Story of my life......Literally
I wish that they would sell 10 lb rolls plus 2ft of wire. Something labeled like this "10lbs+2ft" then you could buy the perfect amount every time!
PostPosted: Tue Jan 21, 2014 11:02 pm
I hate that.. Then you sit there thinking about it the rest of the day.
A little tip.. and its not that big of a deal.. If you were to slow the wire speed down just a fraction it would help with the tiny bit of splatter.
Nothing wrong with the welds.. They look great, Heat setting is just about perfect.
Looks like you're welding using the "push method". I prefer that method as well.
I use a 75/25 Argon/CO2 mix for MIG.. CFH @ 17-20
Once I get the heat right, I just fine tune the wire speed.
They (Your local Welding Supply) sell a spray called "Anti-splatter".. You can spray the area just before you weld and all the little splatter-balls fall right off.
Helps a lot. I use it in hard to reach area's that may be difficult to clean later.
Just something to try :)
The only way you get better at welding is seat time!
By the looks of it.. Your putting in some work.
Mike
Users browsing this forum: Baidu [Spider] and 16 guests
