It is currently Mon May 25, 2026 3:16 pm
 Post subject: LUV Fender Question?
PostPosted: Wed Jan 15, 2014 12:55 am
Hey guy's,
I'm new to these trucks. I have a fender question that maybe someone can help me with?
I have a 75 LUV (Just bought it) and I'm now doing some planning.
I have noticed earlier trucks came with 4 headlights and then they switched over to 2 headlights.
Are the fenders the same? I need to do some modifications and need to know what year fenders I can use.
Appreciate any help in advance.
BTW.. Great site!
Mike
 Post subject: Re: LUV Fender Question?
PostPosted: Wed Jan 15, 2014 1:04 am
Fenders are the same. Some more info...viewtopic.php?f=7&t=27876&p=203804&hilit=4+headlight+conversion#p203804
PostPosted: Wed Jan 15, 2014 1:05 am
Damn!! Your quick! :)
So.. Reading between the lines here..
The fenders are the same?
I did read the post (Maybe too fast?) but its basically telling me I can do a headlight conversion.
I am more interested in the fender.
Mike
PostPosted: Wed Jan 15, 2014 1:47 am
all the fenders were the same 72-80 just different badges and headlight/grille combos. you can look up on the search there is a topic that has a list of year to year changes.
PostPosted: Wed Jan 15, 2014 9:46 am
Thanks for the conformation.
PostPosted: Wed Mar 05, 2014 5:01 pm
I believe there is a slight difference on the fenders where the valance bolts up between them but it is not enough to keep you from using either style valance or even noticing from one side to the other. There is no difference around the headlight trim and nothing that would impact swapping from 4 lights to 2. That is more a function of the core support and headlight buckets. I think you might have to drill a hole or two to go from 4 lights to two, but the structures of the core support are the same.
The bottom clips of the later 2 light style grill do fit into slots in the later style valance so you might have to get creative to hold the grill solid if you want to use a stock 2 light grill along with the early valance. Should be easy enough to fabricate the needed parts, just depends on what parts you want to mix and match.
There are very few major body changes all the way from 72 to 80, and most of them are the tail gate and tail lights.
