It is currently Sun Jun 07, 2026 3:37 pm
PostPosted: Fri Jan 02, 2004 1:12 am
Whats the diff? Is it worth switching?
PostPosted: Fri Jan 02, 2004 1:24 am
the biggest diference is points. The electronic will idle smoother, give bettewr throtle response a little more powere and better econimy. When i switched it was mostly becouse i was sick of my distributor getting wet. Whith the electric one watter isnt as big a deal. When i got it on first thing i noticed was the smoother idle. Then i noticed that when merging onto the freeway there was better power in the higher RPMs and it would rev higher as well. Then as time whent on i noticed i was getting about 1mpg more. I dont remember what it cost me, but i did do a write up on it. Since the swap, i havent looked back 8)
PostPosted: Fri Jan 02, 2004 3:57 am
can you tell me everything i need to do the conversion? and possibly an idea of where to get it?
PostPosted: Fri Jan 02, 2004 4:07 am
you will need the distributor, cap, rotor and controll module from an 82 chevy luv. I was able to get mine from the locals parts store. It will run you a few bucks, so be ready for it.
PostPosted: Fri Jan 02, 2004 9:21 pm
i think their is a conversion kit through jc whitney its about 80 bucks i think :D i was thinkin about doin that myself
PostPosted: Fri Jan 02, 2004 11:52 pm
my luv is a 81 and it has electronic ignition and to my knowledge thats how it came. if i remember right there is a 81 luv being parted out in the classified section. you might check and see if he will part with the ignition.
PostPosted: Sat Jan 03, 2004 1:12 pm
yeah the 81 and 82 luvs came whith the electronic distributor
PostPosted: Sat Jan 03, 2004 11:23 pm
76 thru 80 has the same distributor. The 81 distributor is one digit off (the last one) from the 80 part number. Probably would fit. Then you need the control module.
PostPosted: Sun Jan 04, 2004 9:06 pm
The only electronic distributors are when they changed the LUV's from the pretty shapely LUV's to the PUP looking LUVs. I am taking the electronics out of somne boneyard parts and putting it into my 73 that I rescued out of the woods. I am also going to go snatch the carb sometime this week. I think it might be better to snatch the engine and tranny out and work on it then shove it in the cavities.
Users browsing this forum: Bing [Bot] and 25 guests
