It is currently Sun Jun 07, 2026 6:40 am
 Post subject: Electrical Problem!
PostPosted: Fri Dec 06, 2013 11:49 am
I've got a 74 that will only run on the battery. I have checked and even replaced the alternator and voltage reg but it still wont run off the alt. any ideas? i'm ready to break something!!!!
 Post subject: Re: Electrical Problem!
PostPosted: Fri Dec 06, 2013 6:43 pm
Looks like you will need to do some wiring tracing. The wiring diagram is on the info section of the site.
PostPosted: Sat Dec 07, 2013 12:36 am
Does winshield washers and cigarette lighter both work? If not then blown fuse for regulator also.
