It is currently Sun Jun 28, 2026 10:12 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 04, 2013 9:15 pm
hotrod80 wrote:
Finished up the firewall clean up , header install , carb on , distributer assembled , crossmember modded for larger pan , driveshaft in .
Looking good!
PostPosted: Sat Jan 05, 2013 7:44 pm
LSX LUV Owner
looking great!
PostPosted: Mon Jan 21, 2013 9:16 pm
Ran into a snag . Motor mounts were welded in 3/4 " to far forward . This would not allow me to get the water pump and fan installed . Back to the chassis shop for thr mounts to be cut out and moved . Also had a few other things done . Had hooks weled to the frame to strap truck down , panels made for speakers in rear cab corners , battary tray cut out & a set of universal traction bars cut up and welded to the rear shock mounts . Pics to follow .
PostPosted: Sat Jan 26, 2013 10:54 pm
Got the motor back in . been a busy weekend so far .
PostPosted: Sun Jan 27, 2013 9:59 am
LSX LUV Owner
looks good!
PostPosted: Sun Feb 03, 2013 8:30 am
Got some time to workon this . I dont think im going to have it ready for the season opener , but im trying .
This is the material for the interior . I am having the door panels , seat , kick panels redone .
I got the cooling system completed yesterday . I bypassed the cable heater block valve , as i have never had one that didnt leak . I added a manual valve for summer when the air is on . Got the Condensor and liquid line filter drier mounted and hooked up . All that is left is the compressor mount and hook ups for A/C . Well enough talk here is the current picks .
PostPosted: Sun Feb 03, 2013 7:28 pm
LSX LUV Owner
Looking good. That front bumper looks nice.
PostPosted: Mon Feb 11, 2013 8:35 pm
Did a little more on it , but not much . Not going to make the season opener with it . I was planning to have my wife drive it and contend for rookie of the year .
PostPosted: Mon Feb 11, 2013 10:09 pm
Too bad, it looks pretty close
PostPosted: Tue Feb 12, 2013 12:29 am
it is really close . I am not giving up , just have to make sure the Yellow one is ready . I hate rushing things cause i enjoy working on them so much .
PostPosted: Mon Mar 04, 2013 9:24 am
Just a small photo update so you know it's not dead . Been on stuff that doesnt show . Radiator/cooling system is done . Transmission done cooling lined , converter bolts , shifter . Brakes are complete including e-brakes . anyway working on electrical then moving to fuel .
PostPosted: Mon Mar 04, 2013 9:36 am
LSX LUV Owner
looks good!
PostPosted: Tue Apr 02, 2013 8:00 am
Upolstry off for redo . Door panels , seat and kick panels . Factory tank is being sumped modded and coated . Glass is out for new winsheild gasket and rear window seal . Dash repair in progress for new dash cap . Stereo going in new speaker panels covered and onstalled . Lots of little stuff done . Throttle pedal modified and cable fitted and installed . Choke cable installed ( this will also double as a staging RPM tool with the choke flap removed ) . Reused one of the vapor recovery lines from the tank as vacuum for modulator valve . Moved wires around in harness to make factory relays work for fuel pump and distributor instead of ballast bypass and combo fuel pump/distributor . Truck is getting really close .
PostPosted: Thu Apr 11, 2013 8:45 pm
Made heat with this one tonight . Had #6 top dead , but after thst is busted right off . Good running litlle motor .
PostPosted: Thu May 02, 2013 8:02 am
This truck is finished and has a new home . Just figured i would post up the finished photos .
PostPosted: Thu May 02, 2013 9:50 pm
:ebiggrin
PostPosted: Sat May 04, 2013 10:33 am
LSX LUV Owner
looks great
PostPosted: Wed Dec 04, 2013 3:27 pm
Small update : the new owner overevved the motor at the drag strip and cavitated the oil pump . This killed 5 rods . All the bearing were specked . Crank was galled . Piston rings were not even seated yet . New owner bought a 383 and i installed it . There is more to the story , but i dont want to post it online .
PostPosted: Mon Jun 08, 2015 7:34 pm
Looks like im getting it back
PostPosted: Mon Jun 08, 2015 7:36 pm
Is it in good shape still?n Or was it torn up?
