It is currently Thu Jul 02, 2026 6:34 am
PostPosted: Tue Nov 26, 2013 9:17 pm
Wondering what you guys with v8s in your luvs are using for your exhaust, have the 350 in my truck, it looks like some rear dump ramhorns will work, but I would rather have headers.
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Tue Nov 26, 2013 9:31 pm
I have the hooker headers that are made for the LUV/small block combo.
PostPosted: Tue Nov 26, 2013 10:35 pm
I have the old ramhorn manifolds now but have a set of block huggers to put on when I put in my new motor.
PostPosted: Sun Dec 01, 2013 11:59 am
Thanks guys, luvtrkr, what size exhaust is on your truck?
I'm workin' on it
SBC
PostPosted: Sun Dec 01, 2013 12:29 pm
I'm guessing 1 3/4" tops with 2 glass packs right now. When the headers go on they will be 2" into flowmasters.
PostPosted: Sun Dec 01, 2013 3:41 pm
http://www.summitracing.com/parts/hok-2 ... luv-pickup
Here are the Hooker Headers made for the small block LUV.
PostPosted: Sun Dec 01, 2013 9:11 pm
Thanks for the link luvrv8! If only I could find a set a couple hundred cheaper
I'm workin' on it
SBC
PostPosted: Sun Dec 01, 2013 9:42 pm
I think I still have a used set...
PostPosted: Sun Dec 01, 2013 10:18 pm
What engine mounts will you be running? If you run power by ace mounts you will need his headers, if you run hooker mounts you will need their headers. I made my own mounts and was able to fit the Hooker Headers in there. My engine is set back a bit more then most and it's lower then most.
PostPosted: Sun Dec 01, 2013 10:41 pm
I'm not sure yet. Are the hooker mounts better? The power by ace ones seem a little flimsy to hold up to the weight and power of a v8, but I like how they bolt right in.
I'm workin' on it
SBC
PostPosted: Sun Dec 01, 2013 10:46 pm
I have this set up installed now, and it seems ok to me...
PostPosted: Sun Dec 01, 2013 10:47 pm
I used the power by ace mounts in mine. They are a lot tougher than they look. They are also slotted so you can move them about a half inch back and forth. This makes getting the engine in place a lot easier. I liked them. I can't say they're better or worse than the hookers though.
Mytmouz has my old truck. Maybe he can weigh in on what he thinks of the setup.
PostPosted: Sun Dec 01, 2013 10:48 pm
Oh. He just did.
PostPosted: Mon Dec 02, 2013 5:53 am
I have used block huggers (Hooker) with fabbed mounts and the Hooker system on my current truck . The only down fall to the Hooker stuff is the slip joint . I made a flange for mine which works great ,
PostPosted: Tue Dec 03, 2013 10:54 pm
Thanks guys, ill probably end up using power by ace mounts, or fab some up
I'm workin' on it
SBC
PostPosted: Tue Jan 07, 2014 2:46 pm
do you guys think these will work with power by ace mounts?
http://www.summitracing.com/parts/sum-g9060/overview/
I'm workin' on it
SBC
PostPosted: Wed Jan 08, 2014 10:45 am
I know for a fact they will not. The mounts are in the way. Bad. If you're going to use the power by ace mounts, your only option for headers are the power by ace headers. You might be able to make some rear dump manifolds work.
PostPosted: Wed Jan 08, 2014 7:21 pm
Thanks for the info!
I'm workin' on it
SBC
PostPosted: Mon Jan 13, 2014 1:30 pm
I used the Hooker headers also. They have gone up quite a bit in price since I bought my set though!
I run 2 inch pipe all the way to Corvair Turbo mufflers. Sounds good. They are quiet until you put the metal down then they are flow thru and a bit loud.
Users browsing this forum: Google [Bot] and 28 guests
