It is currently Sun Jun 07, 2026 2:23 pm
 Post subject: HELP: Carburetor diagram
PostPosted: Fri Nov 15, 2013 12:51 am
does anyone have a diagram of where the jets should go? i am rebuilding my stock one and managed to have one jet with nowhere to put it!!!
PostPosted: Fri Nov 15, 2013 10:29 am
http://www.luvtruck.com/Information.htm
Look in the parts manual. Do you have a repair manual? If not you really need one.
PostPosted: Fri Nov 15, 2013 11:17 am
Thanks. I figured it out last night. I had to walk away for a few minutes and give my eyes and brain a rest then I figured it out immediately.
I don't have a shop manual and I don't usually buy them because I have "all data" on my computer but it only goes back to 81 and there's no diagrams of the carburetor for that year either. Guess I'll be buying a shop manual in the near future.
PostPosted: Fri Nov 15, 2013 12:13 pm
Factory manuals can be found cheap on e bay. This is a must have. I too have access to all data, Mitchell on demand and I still own a factory manual.
PostPosted: Fri Nov 15, 2013 11:13 pm
great im going to watch for a manual on ebay. do i need to look for my specific series or will any 1st gen 4x4 manual be the same mechanicaly? dont care about cosmetic differences necessarily.
PostPosted: Sat Nov 16, 2013 8:16 am
The only mechanical difference I know of between the Series 9 & 10 4x4 trucks is the clutch & flywheel; Series 10 uses an 8-1/2" clutch & matching flywheel (same setup as used on all trucks with the 1.9 engine) while the Series 9 uses the same 8" clutch & matching flywheel used on 2wd trucks with the 1.8 engine.
PostPosted: Sat Nov 16, 2013 11:21 am
Awesome! I'll just look for a series 10 to be on the safe side.
