It is currently Sun Jun 07, 2026 1:14 pm
PostPosted: Tue Nov 12, 2013 11:57 am
My 80 Luv has a slider and I acquired a solid back glass for it. I needed a seal so I went on eBay and bought a vw seal based on the description '68-79 Bus side center window seal w/o vent. When it arrived the part number reads 221-321C and states Cal Look. I'm not familiar with the bus and its styles, but on a thread on this site it states to use part number 221845321A. Does anyone know the difference or another alternative seal to try? The one I ordered does not fit.
PostPosted: Tue Nov 12, 2013 12:25 pm
I found this seal, but it states 72-82 which throws me off since I think the rear glass is probably different in an 81 or 82.
m.ebay.com/itm?itemId=310321130652
PostPosted: Tue Nov 12, 2013 12:26 pm
I have used the Courier seal twice with no problem Cut to fit square and super glued together . I'll see if i can track down a number
PostPosted: Tue Nov 12, 2013 12:27 pm
Thanks, do you have any pictures of it installed?
PostPosted: Tue Nov 12, 2013 7:32 pm
Cal look means no chrome trim.
PostPosted: Wed Nov 13, 2013 10:05 am
I also have not turn up any seal that will accept the chrome trim for thr rear window or the windsheild .
PostPosted: Wed Nov 13, 2013 10:40 am
I'm going to try to find a universal seal that will work hopefully.
PostPosted: Thu Jan 23, 2014 2:13 pm
did you have any luck with the solid rear rubber seal if not let me know I have a new in the sealed package fits great I used one on my luv and it is still on my luv works great I will see if I can get some more pics of it today
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Jan 23, 2014 2:31 pm
this was a few years back and I still have the same one on my luv truck as of today
budbondo wrote:
this is the new window rubber on the stock glass it fits great and then i put the new rubber on my flex window the window is a lil smaller but it fits great
dangerous-toys4life
75 k-5 2x
94 king cab
