It is currently Sun Jun 07, 2026 2:22 pm
 Post subject: fading brakes
PostPosted: Sun Dec 28, 2003 6:54 pm
I've got a problem with my brakes. When I come to a stop, while holding the pedal down if I keep hard pressure on it, it is just fine, but if I let up on the pedal at all, even just a little bit, the pedal loses pressure and goes all the way to the floor and I lose my brakes. I've looked all over for a leaking line but found none. There's a tiny hole on the booster just under the master cylinder flange and a little fluid seems to be coming from there, but it only seems to do it while the truck is parked. Any ideas???
Ken
PostPosted: Sun Dec 28, 2003 9:55 pm
you have a bad master cylinder its not holding up to pressure the fluid you see leaking is brake fluid leaking out of the back of the master cylinder.
PostPosted: Mon Dec 29, 2003 7:48 am
You might just have air in your lines. Try bleeding your brakes.
PostPosted: Mon Dec 29, 2003 12:14 pm
Thanks guys. I'll try bleeding the brakes. Would have done that already but don't have much time to do anything. Does anyone sell a rebuild kit for the master cylinder or am I going to have to buy a new or remanufactured one?
Thanks
Ken
PostPosted: Mon Dec 29, 2003 2:47 pm
You might try looking on ebay for a NOS master cylinder there is usually a couple on there.
Resident lurker
PostPosted: Mon Dec 29, 2003 3:06 pm
Thanks everyone. I'm getting a remanufactured master cyl from O'Reilly's. It's kind of funny though, the rebuilt master is a dollar less than the rebuild kit to do it myself. Either way I've got to wait until tomorrow to get it. Thanks again everyone.
Ken
PostPosted: Mon Dec 29, 2003 4:15 pm
well good luck whith that. Remember that when you de any brake work youll have to bleed the brakes to get the air out so they dont dead pedal.
PostPosted: Mon Dec 29, 2003 7:49 pm
i'd advise you not to get that oreily master cylinder, if its the cheap lifetime warranty one. i have one and i'm on my 4th or 5th. i've lost count. the only reason i keep putting them on there is cause they are free, since the lifetime warranty. one of them was bad off the shelf. after replaceing your fourth one u start to regret getting the cheap one. the one i have on now is even starting to go out.
PostPosted: Mon Dec 29, 2003 9:55 pm
I hear what you're saying. I've been through the cheap part routine a few times. Right now it's the only option I've got though. It sucks but I'm prepared for it. Thanks for the info though.
Ken
