It is currently Mon Mar 23, 2026 7:16 pm
 Post subject: rear end question
PostPosted: Wed May 15, 2002 5:43 pm
I have a '77 and was wondering what gears are in it from the factory? Also I was told that it was a Ford 8 inch rear, is this true? Thanks :microwave:
PostPosted: Thu May 16, 2002 3:35 am
Don't know about it being a ford 8inch, but the factory gears were 4.56 for standards and 4.11 for auto.
PostPosted: Fri May 24, 2002 9:39 pm
Just wanting to know if gear ratios are the same for '74 2wd.
PostPosted: Sat May 25, 2002 1:39 am
From what i know it was the same for all 2wd's
PostPosted: Wed Jun 05, 2002 3:47 pm
Just to clarify what Bob posted, he is correct. I looked up the rear-end parts info in my factory parts book and the ONLY two ring and pinion sets listed for all years 72-81 are 4.56:1 for manual, 4.10:1 for automatic.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
 Post subject: rear ratio
PostPosted: Wed Jun 05, 2002 6:01 pm
I just replaced the bearings in the rear of my luv 4X4. The ratio was 4:10. It also has factory air. Could it be that (air) is the reason for the 4:10 ratio?
PostPosted: Wed Jun 05, 2002 6:15 pm
Maybe someone swapped rears/gears on the truck?
63 Nova
74 Camaro
PostPosted: Fri Jun 07, 2002 3:52 pm
Rick I also have a 4x4 luv and I have 4.10 gears in it . I believe all 4x4's came with 4.10 gaers. everyone I have talked to with a 4x4 has 4.10 gears.
PostPosted: Sun Jun 09, 2002 7:23 am
the 4x4s propably used the 4.10 ratio because of the gear ratio in the transfer case. and tire size can make a diffrence.
