It is currently Sun Jun 07, 2026 7:11 pm
PostPosted: Thu Oct 31, 2013 8:52 am
My Luv doesn't have any sort of unit in the dash and the black vinyl is all gone, so it's just a blue dash with a hole for a cd player. I put a sleeve from a cd player in the hole and the hole is too big. Also I cannot find an install kit that will work with this truck. What route have you all taken to install a headunit in your 1st gen LUV?
This is someone else's picture, but my dash looks just like this right now:
PostPosted: Thu Oct 31, 2013 9:05 am
My CD player fit just fine in the stock location, is it possible yours has been cut to be bigger?
PostPosted: Thu Oct 31, 2013 9:09 am
Alright I think I figured it out, the sleeve is just slightly smaller than the hole and the hole hasnt been cut. I see holes on the bottom, I'm guessing I can put screws through the sleeve into those holes to mount the cd player and wire it up and call it a done deal. Is this how you all mounted yours?
PostPosted: Thu Oct 31, 2013 10:33 am
My radio has a sleeve that mounts and has tangs that push out and lock the sleeve to the dash, the front of it has a lip that won't go through the hole. The rear has a stud that a strap bolts to the dash and supports the rear of the sleeve or cage. After it is mounted the radio slides into the cage or sleeve.
PostPosted: Thu Oct 31, 2013 11:23 am
Thanks, that will work, but I do not have the strap. I'll figure that out, thanks!
PostPosted: Thu Oct 31, 2013 11:43 am
Plumbers strap from Home Depot
PostPosted: Thu Oct 31, 2013 4:49 pm
Some assembly required
