It is currently Thu Jun 25, 2026 3:43 am
Post new topic Reply to topic  [ 189 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Fri May 24, 2013 5:04 pm
Haven't done very much on the truck since the last post, still working on it though, just very slowly.
My names Trevor BTW. ;)
PostPosted: Sat May 25, 2013 10:46 pm
PostPosted: Wed Jun 19, 2013 9:22 pm
purchased coilovers. QA1 Adjustable 12 Inch Coil-Over with 10in 350lb springs
PostPosted: Sat Jun 22, 2013 1:48 pm
Modifying the strut housing to fit the coilovers.
Going to cut a recess to help with the clearance at the bottom of the strut housing, the reason I'm doing this is to keep the 10 degree slope of the original suspension.
PostPosted: Wed Jun 26, 2013 10:41 pm
got my rack and pinion and worked on the coilover mounting mockup.
Made a recess in the old housing to clear the coils and started the cardboard mockup of the top cap. Where the black dots are there will be plug welds for the cap reinforcement strap
PostPosted: Sun Sep 15, 2013 5:53 pm
Fare amount of progress. Picture heavy. the front suspension is now finished, time to move on to the steering.
PostPosted: Sun Sep 15, 2013 5:54 pm
PostPosted: Sun Sep 15, 2013 10:14 pm
I must be missing something, but how do you get the upper shock bolt in?
PostPosted: Sun Sep 15, 2013 11:18 pm
Going to use a hole saw and cut a hole for a socket to go through.
PostPosted: Thu Sep 26, 2013 10:20 pm
PostPosted: Thu Sep 26, 2013 10:34 pm
Going to need to change the springs to an 8in instead of the 10in, so the ride height will be right, sitting at 8-1/2in ground clearance needs to be at 6-1/2in . Also need to change to a lower spring rate, #350 is what have in now, probably going to go with a #250, any suggestion?
PostPosted: Sat Oct 05, 2013 12:38 pm
Should be getting the new springs some time next week.
PostPosted: Mon Oct 07, 2013 8:07 pm
got the springs today, decided to through some things together and start mocking up the rack and pinion, and yet another issue has arisen. going to have to sleep on this one. 1 step forward 2 steps back.
PostPosted: Sun Oct 27, 2013 10:55 pm
Made some progress this weekend.
Someone had asked about how I bolt the coil over up on the top mount and this picture is in reference to that.
The rest are recent work.
PostPosted: Mon Oct 28, 2013 7:58 am
Hell ya keep it up!
If the system fucks you. You fuck it back!
PostPosted: Mon Oct 28, 2013 9:53 pm
:popcorn:
PostPosted: Tue Oct 29, 2013 10:35 pm
Tacked the rack and pinion in, set the motor in, and set the cab on.
The reason for this was to see where the suspension was going to sit with the weight of these items.
Everything clears. The only thing I may need to address is the tire to fender clearance during compression. That is something I'll look into at a later date.
Going to pull everything back off and finish welding the rack and pinion in the next couple of days.
PostPosted: Fri Nov 01, 2013 3:28 pm
This thing is going to be nasty!
PostPosted: Fri Nov 01, 2013 8:52 pm
man its comin along really nicely cant wait to see it done and running. its gonna handle like a hopped up shiftercart :lol:
PostPosted: Sat Nov 02, 2013 12:45 am
:D
Thank you. as for the shifter cart handling, that's kind of what I'm going for atm. Although that was not the intention when I started, but after getting the motor and doing some measuring, it was clear some things were going to have to be changed. I may at some point do a corvette independent rear suspension just to add to the shiftercart feel. :)
