It is currently Sun Jun 07, 2026 8:21 am
 Post subject: 1978 Chevy Luv Radiator
PostPosted: Thu Oct 17, 2013 4:58 pm
Aloha, my name is Kereem Justice and I am a new Chevy Luv owner.... I have a 1978 Chevy Luv Truck and I need to replace my radiator. Any suggustions where to find a replacement.
My second question: I need to replace my Pedal Cluster assembly kit, how do I disassemble the cluster and where can I purchase a new or used one? Mahalo Boys....
PostPosted: Thu Oct 17, 2013 5:45 pm
Not sure about the radiator, junk yard maybe? The peddles are seperate, the clutch is connected to a frame up under the dash where it pivots, and fails very on a lot of trucks. I removed mine and rewelded some supports and put it back on. What I found was the clutch cable had cut into the sleave through the fire wall. Greese it up spin it around and it will work well for you. welcome to the site. Look around and you will be suprised what you find here. I use it all the time
Users browsing this forum: Bing [Bot] and 51 guests
