It is currently Sun Jun 07, 2026 1:04 pm
 Post subject: weber carb.
PostPosted: Sat Dec 27, 2003 1:10 am
Any suggestions on where to buy a weber carb. Thanks for help.
Thanks Derrik
PostPosted: Sat Dec 27, 2003 9:33 am
OG Lifer
this is one place
Or
this is another good one
Either place is good, I bought mine from carbs unlimited.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sat Dec 27, 2003 9:42 pm
i see you're in washington. carbs.net has a warehouse in fife. i ordered a new air cleaner assembly this summer from them, and got it less than a day later!
PostPosted: Sun Dec 28, 2003 11:23 am
hey thanks for the diff place to get a carb now i gotta get one. Oh and yeah i actually got my luv down in lacy from luvsick i dunno if u know of him or not. It was a long drive but worth.
Thanks Derrik
PostPosted: Sun Dec 28, 2003 1:47 pm
Hey Mad, did you get the truck running ok? I was just wondering cause I know he was having troubles with the carb and I loaned (another story) :lol: him mine to help him get his truck home. The last I had heard was that he couldnt get it running so he was getting rid of it.
I was wondering if you had better luck than he did?
Later
Husker
PostPosted: Sun Dec 28, 2003 4:09 pm
LOL hows it going? Ur the guy with the other carb. yeah he told me the story. I took the luv to my mechanic and he said that he could rebuild it, but it wouldn't run to its capability. So i baught a rebuilt one from a fella in cali. And it runs awsome but i eed a new carb b/c it starts to spudder and then i pump the gas and then it runs good till i shift gears then i have to do it agian. But all in all it runs good and i luv the truck.
Thanks Derrik
PostPosted: Sun Dec 28, 2003 9:14 pm
Yeah I'm the other guy !! and I can only imagine what he told you. :evil: Well anyway glad to hear that you got it running
Later
Husker
PostPosted: Sun Dec 28, 2003 9:46 pm
i got my weber for christmas from http://www.webernorthamerica.com haven't put it on yet i got the luv torn apart to replace a front axle bearing and fix my oil leak. as soon as i get it back together i'm putting it on. i also got a pacesetter header off ebay but it hasn't arrived yet.
PostPosted: Mon Dec 29, 2003 2:19 am
Who did you get a header from off of ebay? Do you know if hes got more? I have been lookin for a header for my 79 chevy luv for months and dont know where to get one.
PostPosted: Mon Dec 29, 2003 2:23 am
also, have to ask... what is the best carb that webers got to use on the luv truck?
PostPosted: Mon Dec 29, 2003 9:23 am
OG Lifer
The best carb to replace the stock one is the 32/36. I have the dgev with electric choke. Depends on what you really want to use.
PostPosted: Mon Dec 29, 2003 12:27 pm
i think a 38mm on the litte 1.8 might be a little much. the 32/36 would probably be a better choice.
now, if it was bored out, cammed up, and had a header it might make things a little different :twisted:
PostPosted: Mon Dec 29, 2003 1:38 pm
ok im not that car smart....whats cammed up? I know my engine was bored for rebuild but dunno bout "cammed up". Whats it take to do it?
PostPosted: Mon Dec 29, 2003 7:45 pm
OG Lifer
Bigger duration, more lift cam. You may have to consult a machine shop, or call competition cams and talk to a tech guy about a special grind cam for higher perf.
PostPosted: Mon Dec 29, 2003 8:25 pm
there is another header on ebay like the one i bought and its the same seller. http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33631 i am very happy with the looks of it, it even came sealed in the pacesetter box. its not flimsy metal like alot of headers you see. also i bought the weber dgev-ic 32/36 this is the electric choke model. i shopped arounf for prices and found it was cheapest to buy it from weber. http://www.webercarbsdirect.com/inc/pdetail?v=1&pid=330
PostPosted: Tue Dec 30, 2003 1:31 am
just as good as weber? http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2450455474
Is there a difference? Also, do i need a different fuel intake to handle the fuel this carb will dump?
PostPosted: Tue Dec 30, 2003 9:55 am
OG Lifer
Nate, I would just save up and buy the weber 32/36 carb. I try not to buy something off of ebay unless I plan on rebuilding it anyway.
PostPosted: Tue Dec 30, 2003 4:11 pm
there's often good deals on new webers on ebay to be had
i have a manual choke 32/36 in my toyota, it's a good carb but the choke is a pain in the ass. if i had any say in it, i would have gotten a water choked weber. it taps into the cooling system and gradually opens the choke plate as the engine warms up
PostPosted: Fri Jan 02, 2004 12:19 pm
Would a Carb out of a 81 Series engine work on a 73? I want to dump that manual choke. The other problem that I have is that the carb stands up too high so I can't put the air cleaner on the engine where it needs to go without having the hood popped open
Lemme kno!
Users browsing this forum: Bing [Bot] and 28 guests
