It is currently Sun Jun 07, 2026 2:21 pm
PostPosted: Sat Dec 27, 2003 11:15 pm
Well i had my luv out on the road for the first time in about 4 weeks. Ah the new parts in the front end are so nice. I rides and drives soooo much better. Now tomarow i get to takel the rear end, thats just bearings and seals though. SHouldnt take but an afternoon is all. :D 8)
PostPosted: Sun Dec 28, 2003 9:09 am
OG Lifer
Excellent. I am hoping to tackle mine in early spring.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sun Dec 28, 2003 3:01 pm
is you LUV a 2wd? If so then you wont have to wait on some of the parts i did. Thats why my front end rebuild took me a month 8O
PostPosted: Sun Dec 28, 2003 9:00 pm
OG Lifer
Nope. 4WD. I have alot of the parts, just not alot of time :wink:
PostPosted: Mon Dec 29, 2003 4:12 pm
well i did the rear but found out i put the inner seal in backwards :oops:
Oh well it was actually perty easy to do the rear, ill just be swapping out that seal this weekend.
As far as your front end rebuild goes, there are a few parts that youll need that you might have. On the back sode of the steering knuckle there is a seal (mine was brass and it is ridged) then there is a vary small cage bearing that supports the CVs. Other than that the front end is just inner and outer bearings, one regular looking seal and ball joints. Good luck. :D
PostPosted: Mon Dec 29, 2003 11:11 pm
OG Lifer
Yeah, I am gonna do the ball joints, tie rod ends, a-frame bushings, etc. I want it to not clunk when I drive down rough roads.
PostPosted: Mon Dec 29, 2003 11:23 pm
wow yours was clunking!? mine whasnt that bad, i just couldnt get it aligned :lol:
PostPosted: Tue Dec 30, 2003 9:57 am
OG Lifer
I turn a corner, and the front end clunks to one side. After I straighten the wheel again, it clunks back to center. It is REALLY worn out. We lived out in the boonies for a long time, and my dad drove it to work everyday. It has seen alot of rough miles.
PostPosted: Sun Jan 04, 2004 8:57 pm
On nearly all of my trucks they had that rear axle whine that was nearly so loud that it drowned out the radio. I could never find the problem.
Anyone else find the problem? I remember replacing the universals, taking the bearings out, re-doing the transaxle, and even replacing the transmission filters and it still whined. Is that why you are doing yours?
PostPosted: Sun Jan 04, 2004 9:04 pm
OG Lifer
Rear axle whine sounds like incorrect gear mesh to me. The pinion isn't making the correct amount of contact to the ring gear. At least that is what it sounds like from behind this computer screen.
PostPosted: Sun Jan 04, 2004 9:20 pm
I think I tried adjusting the gear mesh as well, but those were days long gone by. I think with this truck I will pull it and do a complete overhaul of the rear axle and see if there is anything preventative that I could do before putting it on the road.
PostPosted: Mon Jan 05, 2004 12:42 am
i know my my tranny makes a nice whine in first gear and reverse. But thats just normal and its barley audiable. It could be that things were just worn. I have never head anything like that before though.
PostPosted: Fri Jan 09, 2004 8:01 am
I think what I will do is order the parts now and repair them when they are all in. Gives me a chance to look to see if the parts are the same before tearing the machine apart.
