It is currently Wed Sep 03, 2025 2:48 pm
PostPosted: Fri Aug 23, 2013 2:28 pm
So I got new rotors brakes and shocks the rotors and shocks went smooth but when I get the brake pads in the caliper they won't fit around the rotors. It's compressed all the way and the side with the piston is fine but the outer brake needs to be pushed in farther it's a 78 chevy luv any help would be much appreciated!
PostPosted: Fri Aug 23, 2013 3:22 pm
The rotors you bought, are they vented or solid? How much thicker is the new rotors then the old ones?
PostPosted: Fri Aug 23, 2013 3:25 pm
They are solid and I'm not sure I'm not home right now I've been trying for the last few days and am starting to lose hope
PostPosted: Fri Aug 23, 2013 3:30 pm
New rotors and pads make for a tight fit. Make sure the caliper pistons are even with the caliper.
PostPosted: Fri Aug 23, 2013 4:26 pm
They are that sides not the problem it's the other side opposite side of the piston
PostPosted: Fri Aug 23, 2013 6:22 pm
Are you sure the rotors are on correctly? Post a pic and we can help. Just so we understand, is the caliper mounting bracket on and now the caliper won't fit? Here is a pic of a caliper and bracket installed.
http://www.luvtruck.com/Information/Brake_swap.htm
PostPosted: Fri Aug 23, 2013 10:14 pm
I got it figured out they're were pins on the caliper that had to be removed so the caliper would open up!
Users browsing this forum: No registered users and 67 guests
