It is currently Mon Mar 30, 2026 12:30 pm
PostPosted: Fri Aug 02, 2013 4:40 pm
i have a 1979 chevy luv there is a box under the hood on the passenger side on the finder close to the fire wall and there is two relays under it one of them is rester bipass relay and i dont know what the other one is andit is bad and when i turn the key the truck wont even turn over but the fuel pump and everything eles still comes on and i can start if i tuch the two ends on the starter together with a screw driver ad it will run just fine but te key wont start it and i wuld like to know what that other relay is caled and where i might be able to purchase one of thses relys because its just a pain in the butt o start it with a screwdriver all he time
PostPosted: Sat Aug 03, 2013 1:44 am
That other relay is the fuel pump relay. If you have no start, no nothing, check the clutch switch located up on the clutch pedal lever.
PostPosted: Sat Aug 03, 2013 4:06 pm
the clutch sensor up under the dash is good when i turn the key on the fuel pump andi have and electric fan on it and itstill comes on i took that sensor off and opened it up and its all burnt on the inside and ivehad my gerandpa lookj at ig and he said that the fuell relay is bad i just need to know where i might be able to get one
PostPosted: Sat Aug 03, 2013 5:59 pm
Does the truck turn over? If not the fuel pump relay has nothing to do with it. By pass the clutch switch.
PostPosted: Sun Aug 04, 2013 2:04 pm
the clutch switch has already been by-passed. the truck starts and runs fine when I short across the starter. I need a new fuel pump relay...the insides of mine are fried...where can I buy a new fuel pump relay?
PostPosted: Sun Aug 04, 2013 5:50 pm
Listen to the question......
Does the truck turn over with the key?
When jumping the starter does the truck stay running?
Just trying to help you.
PostPosted: Sun Aug 04, 2013 9:37 pm
no it does not turn over with the key...it starts and runs perfect when shorted across the starter
PostPosted: Sun Aug 04, 2013 9:52 pm
If that is correct then your fuel pump realy is not the cause of the truck not starting. The fuel pump relay has nothing to do with the truck turning over.
