It is currently Sun Dec 14, 2025 11:22 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Next project...
PostPosted: Mon Feb 25, 2013 8:33 pm
If you are too busy to work on it you should TELL your wife to get out there and start cleaning parts to help you out. Make sure she understands that she only needs a few hours of sleep so she can still make you dinner every night and have plenty of time to work out there 5 or so hours per day. Let me know how this works out for you.
PostPosted: Tue May 07, 2013 11:20 am
Finally! Got it to fire up on it's own a few minutes ago. Stupid wiring...
PostPosted: Fri Jul 12, 2013 10:52 am
Occasionally work on this thing as I get time.
Pretty much finished up the engine wiring I hope. This is as clean as it will get, lol...
Going to finish up the stuff this weekend in the inerior and reinstall my buckets and console, got an appointment with the muffler shop monday..
Then I got to go back stockish with the trans. I converted it to non VSS like I had in my v8 blazer, but since this one has an ECM, it needs the VSS info, according to the FI board gurus. Then I will need to get an mechanical speedometer to VSS adapter from JTR so I can keep my stock Nissan speedometer...
PostPosted: Sun Oct 13, 2013 11:17 am
One of these days...
PostPosted: Sun Oct 13, 2013 12:38 pm
F150 bed ?
PostPosted: Sun Oct 13, 2013 9:24 pm
I like the red one...
PostPosted: Sun Oct 13, 2013 10:36 pm
Yes, it is off an 83 F10, and what red one...
PostPosted: Mon Oct 14, 2013 8:57 am
The red and blue luv in the background...
PostPosted: Mon Oct 14, 2013 9:05 am
Someone tell the mods the internet sarcasm button is broken again, lol...
PostPosted: Sat Dec 07, 2013 5:19 pm
https://www.youtube.com/watch?v=TK55PKAKelY
PostPosted: Sat Dec 07, 2013 8:11 pm
31 seconds, that must be a record for you.
PostPosted: Sat Dec 07, 2013 9:40 pm
Not sure how much upload time I am allowed with my service plan...
PostPosted: Sun Dec 08, 2013 1:22 pm
Nice ! heat made
PostPosted: Sun Dec 14, 2014 4:22 pm
And... a long overdue update... I got it mostly figured out and running, but trans no workie except low and reverse. Off to the trans shop in March, got it back today... I have a battery drain with the key off, and something in the wiring for the alternator to figure out, and probably a radiator swap, then body and paint/wheels. Due to the electrical gremlins the test drive was short, but verryyy sweet....
I have to pick up a driver side fender (deer took out the fender and door a few years back, I got the door, and I can do the body. The aforementioned stepside bed will be cut down and installed, so all 3 of my mini trucks will have one, and I have a new cowl hood to put on it. (I REALLY hope it doesn't fit as poorly as the one for the project LUV)... And decide on the wheels. I need to get the bed mounted and see if the stock rear is gonna live before I order those though....
PostPosted: Wed Dec 24, 2014 2:27 pm
Minor update. I got another pig tail for the alternator, the one I had only had one wire, needed 2. Installed it it is charging now, so a road test commenced. With a stock chip for a non vortec tbi and no tuning whatsoever, it runs pretty good. I got to see if I got the battery drain issue corrected with the alternator repair. Not much else is going to happen until I get my current shop project out of the way...
PostPosted: Wed Dec 24, 2014 3:14 pm
Felt so good I made another test run, lol... Actually, the fuel gauge was low on first run, I was pretty sure it worked, so I went to the station (That is like 20 miles round trip, lol) and got 5 gallons and poured it in, Yep, gauge works. Decided to make another trip, ran smoother the further it went. Temp gauge got a little over halfway, and it is fairly nipply, so I see a radiator core mod and a larger rad in the future...
PostPosted: Sun Mar 08, 2015 6:51 pm
Been driving this thing around. Pretty much got it running like i want it. need to set the timing and check some of the other stuff with the computer, but it is pretty close. I will need a better cooling system than stock, body parts swap, paint, and wheels, but I am pretty happy with it...
PostPosted: Mon Mar 09, 2015 11:21 pm
Looks like it is coming along .
PostPosted: Fri Nov 27, 2015 6:50 pm
Got around to installing the 5 lug front today. The fugly white spokes are strictly to hold up the front end for now...
PostPosted: Fri Dec 25, 2015 10:07 pm
Pulled the rear today, going in with the 8.8, I hope...
