It is currently Mon May 25, 2026 12:29 pm
 Post subject: compatible engines?
PostPosted: Fri Jun 07, 2013 12:35 pm
I have an '80 4x4 with a (recently) shot engine. I am a.) looking for a replacement (in new england) and b.) interested what years are compatible with mine. What about Pups? I'd love to put in a 2.3. Would that necessitate a tranny swap?
 Post subject: Re: compatible engines?
PostPosted: Fri Jun 07, 2013 3:03 pm
I think the tranny wouldn't matter but you might as well put the 5 speed inz
PostPosted: Fri Jun 07, 2013 3:25 pm
Any 4cyl Isuzu engine will bolt to your trans.
To swap a 2.3 you'll probably have to mod the firewall a bit to clear the distributor, you need to use a 4x4 oil pan to clear the front differential & you may need a bigger radiator. Also the LUV fan shroud won't fit a 2.3.
PostPosted: Wed Jan 15, 2014 12:29 pm
This list will let you know which vehicles will have the same motors.
<a href="http://www.rpmrons.com/Isuzukits.html">http://www.rpmrons.com/Isuzukits.html</a>
PostPosted: Wed Jan 15, 2014 1:42 pm
Try bbcode. Nobody's going to let you use html on their forum.
