It is currently Tue May 12, 2026 10:56 am
 Post subject: SR20de Swap In Chevy Luv
PostPosted: Thu Feb 28, 2013 10:46 pm
I'm building my 1977 Chevy Luv into a drift truck, as far as I'm concerned it has never been done before?
Any ways I've found a SR20de engine that comes with Tranny, Ecu, Harness, and MAF for $1000.
It has 45,000 original miles on it, it's a crate engine that im buying off my friend MAYBE
The issue I see with buying this, is I don't know how the Engine will mount into the Chevy Luv?
I was wondering if anyone has done this swap? And if so was there any major fabrication needed? And how close of a fit was the SR20de to stock engine mounting place?
P.S. I don't want to put a V8 in it because, in my opinion it's to mainstream for the chevy luv, and I want to build a drift truck out of the SR20de considering I'm a fan of that engine.
Thank you for any help I can get for this project. - Brent_R
PostPosted: Fri Mar 01, 2013 12:29 am
P.S. I don't want to hear about how I shouldn't turn this truck into a drift truck, or about how I should but a V8 in it instead.
First post and an attitude... Good luck...
PostPosted: Fri Mar 01, 2013 12:48 am
How's that? I changed my wording around a bit with some reason.
And if you think I had an attitude, I'm sorry I wasn't reading it that way when I was typing but can see where you are coming from on it.
PostPosted: Fri Mar 01, 2013 1:17 am
there is a member on the forum thet put an sr20det/5 speed in his luv after abandoning an ej25 swap so its been done at least once
PostPosted: Tue Jun 04, 2013 3:44 pm
did this swap ever happen????
'78 2wd LUV, Betsy, THE LUV MACHINE
PostPosted: Fri Oct 11, 2013 6:40 am
Yes the swap has already been done before I forget the members name though. He used a sr20 redtop.
