It is currently Sun Jun 07, 2026 8:00 am
 Post subject: 73 water pump
PostPosted: Fri May 31, 2013 8:58 pm
There has to be some kind of trick to replacing a water pump on a 73. There is one bolt tucked up behind the front timing chain cover, it would not be a problem but I replace the head gasket and the new felpro gasket blocks me from getting to that bolt. The only other way I see is to remove the front cover first.
 Post subject: Re: 73 water pump
PostPosted: Fri May 31, 2013 10:23 pm
On the 73 to 75 engine there is one bolt behind the timing cover that you have to loosen, not remove. There is a slot the the water pump housing slides behind the bolt.
Users browsing this forum: Bing [Bot] and 19 guests
