It is currently Sun Jun 07, 2026 7:29 pm
PostPosted: Wed May 15, 2013 11:13 pm
Hey guys so I have my truck running so good now I'm thinking of doing rims and tires but I have the big hub there and I need them removed is there some spindles that I can get from another car or do I need to remove stuff please let me know thanks guys
1979 Chevy luv 4x4 pretty stock but I keep her clean
PostPosted: Thu May 16, 2013 1:22 am
Australian LUV Guru
Choose a wheel suitable for 4wd's or swap out your spindles for 2wd luv items.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu May 16, 2013 11:20 pm
Is there an alternative beside the 2wd luv can I use a s10 or other trucks in Cali I can't really find a 2wd Luv or any luv that easily
PostPosted: Fri May 17, 2013 3:02 am
Don't dismantle your truck just for a set of wheels. :smt011 If you were to swap spindles, and it all worked out well, you would also have to remove the front drive shafts so they don't flop around under there......You'd just open up a big barrel of pain in the ass. Leave the hubs as they are, and find wheels you like that fit a 4X4 LUV. There should be many choices of wheels that have the larger hub hole for a 4X4. :wink:
PostPosted: Sat May 18, 2013 4:43 pm
:signiagree
Took me almost 3 weeks to find a decent set of wheels on CL for my 4x4. Everyone was either insane on price for just wheels, or a decent price for wheels and tires but the tires would always be 32's and up, or somebody would beat me to a good deal. Finally got a set of Toyota 15's that fit perfect, even my stock center caps fit.
PostPosted: Tue May 21, 2013 9:33 pm
Yeah I guess I'll have to leave it I tried looking for nice rims to stick with the 4x4 but can find a good set im going to the junk yard see if I find a 2wd luv. Can I take the spindles off that should work right?
PostPosted: Tue May 21, 2013 9:38 pm
Not really. What will you do with the CV joints and axels? What will you do with the front differential?
Again, if you don't want the 4X4 then sell it and get a 2wd.
PostPosted: Thu May 23, 2013 5:42 pm
Well thinking of taking all that off I guess?? I'm currently looking for a 2wd luv to buy umma take the whole truck and change them around my body is pretty straight and no rust so that's the plan I guess I just thought I could've worked with it what I got instead of buying more Luvs
