It is currently Thu Mar 26, 2026 4:01 am
PostPosted: Sun Apr 28, 2013 2:14 pm
Hi I have a 1989 chevy luv with 1.8l i just replaced the head gasket and checked the head and block. Can some tell me any other ideas. i was think in might still water in the oil pan when i changed the head gasket. truck has all the power, doesnt over heat, and radiator does not drop oil. thanks for the help
PostPosted: Sun Apr 28, 2013 3:28 pm
Did you do a oil change while doing the head gasket? I usually do then flush the oil system after a hour of running.
PostPosted: Sun Apr 28, 2013 5:21 pm
1989?
PostPosted: Sun Apr 28, 2013 5:39 pm
I am guessing a 79. If you have a cooling system pressure checker I would pump it up to 10lbs and see if it drops. I am guessing you never got the coolant out of the oil system when you did the head gasket.
PostPosted: Sun Apr 28, 2013 10:31 pm
oops i ment 1980 and ya i figured this to thanks for the help :)
PostPosted: Wed May 01, 2013 9:05 pm
Minitrucker.....Did you actually have the head magnafluxed? I had that problem and though you couldn't actually see it, my head was cracked. Had to get a new one--rebuilt. Though yours may just be residual H2O from the first job. It's a real pain in the..... to take it off again. Did you run the cylinder compression? Sometimes the head gasket will leak next to the #2 cylinder. There is a pressure oil gally there and If you didn't get the head torqued correctly, it could leak there. Check the torque before you pull the head again......
PostPosted: Wed May 01, 2013 9:25 pm
I might be wrong but I thought you could not magnafluxed, it has to be pressure checked.
PostPosted: Sat May 04, 2013 11:09 am
Luvrv8....I think you're right. I remember now that the head exchange shop had to 'cover all the holes' and pressure test it. Thanks.....
