It is currently Tue May 26, 2026 8:41 am
 Post subject: Low Luv
PostPosted: Thu Apr 25, 2013 9:40 pm
So after months of me deciding where I want to go with my 79 Chevy Luv, I've finally decided.
I want to drop it low.
So far the torsion bars are cranked all the way down, and in the rear it has 3in lowering blocks.
Here is 2 pictures of it.
I WANT IT A LITTLE LOWER.
File comment: Little starting fluid, and elbow grease and the Luv started right up and it drove with out skipping a beat.
File comment: The Luv sat under a tarp for about 5 years, was pushed around by a tractor to move it around.
 Post subject: Re: Low Luv
PostPosted: Thu Apr 25, 2013 10:03 pm
If you want it lower in the rear you can pull out a leaf spring. On the front is your rubber snubbers cut down? If not start cutting them down.
PostPosted: Sat Apr 27, 2013 1:02 pm
[quote="Luvrv8"]If you want it lower in the rear you can pull out a leaf spring. On the front is your rubber snubbers cut down? If not start cutting them down.[/quote
I've thought about removing a leaf spring, I most likely will.
I haven't really thought about cutting the rubber snubbers, right now it's sitting on top of them.
How hard is it to cut them?
PostPosted: Sat Apr 27, 2013 1:06 pm
Here is a quick update, I painted inside the cab white.
The color way i'm planning for is White and Black.
File comment: I'm really liking this, it's cool to see the progress.
PostPosted: Sat Apr 27, 2013 3:28 pm
You get a hack saw and cut the rubber down.
PostPosted: Sun Apr 28, 2013 3:24 pm
My snubbers fell right off from being dry rotted--wack them with a hammer once and see what happens
PostPosted: Sun Apr 28, 2013 10:30 pm
I picked up these steelies for the luv today.
Bought them being told they were 15x8s but they are really 16x8s..
PostPosted: Sun Apr 28, 2013 11:04 pm
Before buying tires make sure the offset will work on your truck. Try mounting them on your truck and try to see if the tires will clear the suspension and fender.
PostPosted: Sun Apr 28, 2013 11:19 pm
I might have to do some fender rolling.
I wonder how well that will work with the step side bed sides?
PostPosted: Sun Apr 28, 2013 11:35 pm
Since they are fiberglass it would involve trimming. Determining back space and offset is something that needs to be done before buying rims and tires.
PostPosted: Mon Apr 29, 2013 10:53 pm
Yea I should of checked the clearance and everything, oh and I found out they are 15x8s
I was just measuring them wrong.
PostPosted: Tue May 07, 2013 7:36 pm
Here is an update from the weekend.
PostPosted: Wed May 08, 2013 8:50 am
Can you turn the front wheels lock to lock? I had a set of 15x10's on the front and mine they rubbed.
PostPosted: Wed May 08, 2013 5:27 pm
[quote="LUVTRKR"]Can you turn the front wheels lock to lock? I had a set of 15x10's on the front and mine they rubbed.[/quote
I don't rub what so ever, I have the wheels stretched so that might make a difference.
PostPosted: Sat Jun 01, 2013 9:50 pm
Here is an update, I changed the front brake lines and put in seats.
I forgot to take a picture with both seats in.
PostPosted: Sat Jun 01, 2013 10:20 pm
With a truck that low you might want to add a bit more padding in those seats.
PostPosted: Tue Jul 02, 2013 5:29 pm
Hahah, yea I came up with an idea.
I'm just trying to get ahold of some memory foam for it to happen.
And sorry for not to many updates, just got finished moving recently.
Caused everything to slow down.
File comment: Here is a picture I just found, and forgot to upload.
PostPosted: Tue Jul 02, 2013 5:37 pm
Everytime I look at your truck it reminds me of my first 76 I bought in 1980. If it had International Harvester tail lights I would think it was the same truck. Mine was last seen in Yakima Washington in the late 90's and was made into a drag truck.
This is before the visor was put on mine
