It is currently Wed Jun 10, 2026 2:39 am
 Post subject: TH 200 bolt pattern
PostPosted: Mon Apr 22, 2013 8:53 pm
Guys
I don't have an automatic transmission in my 75 Luv...but I am curious.Does it have BOP bolt pattern or standard Chevy? If I find one I might have to pick one up so my girlfriend can drive one of the Luvs I will have this summer.
 Post subject: Re: TH 200 bolt pattern
PostPosted: Mon Apr 22, 2013 9:03 pm
The 75 LUV has the early g180 engine, it is differant then the later g180 engine, so you can't use the auto from the later LUV, and the BOP and standard Chevy bolt pattern won't work with either.
PostPosted: Mon Apr 22, 2013 9:05 pm
Here's some reading and a few links in the thread.
http://www.chevytalk.org/fusionbb/showt ... id/226673/
PostPosted: Mon Apr 22, 2013 9:49 pm
One of the Luvs I am buying is a 77.But I know where I can find a TH200.I just need to know which bolt pattern. :)
PostPosted: Mon Apr 22, 2013 10:00 pm
I might be wrong but I think the version of the 200 used in the LUV is the only one that will bolt up.
PostPosted: Mon Apr 22, 2013 10:48 pm
The LUVs came with the TH200 Metric.
PostPosted: Mon Apr 22, 2013 10:55 pm
I know they came with the 200 metric, but I think the case was special to the luv. Its a long shot but maybe the same as a Vega.
PostPosted: Mon Apr 22, 2013 11:04 pm
I posted that for Cleaver's benefit.... :lol:
I think the Chevettes came with them also.
PostPosted: Mon Apr 22, 2013 11:28 pm
Thanks guys.I know where there is a Chevette too.The guy will basically give it to me.The 1.6 might be a build idea for a turbo motor.I think they had oilers on the connecting rods for the pistons and piston pins.Maybe a V8 Chevette might be a fun idea..not like I haven't seen it done before. :twisted:
