It is currently Thu May 07, 2026 10:15 am
 Post subject: My 350 Luv engine
PostPosted: Fri Mar 30, 2012 11:53 pm
 Post subject: Re: My 350 Luv engine
PostPosted: Fri Mar 30, 2012 11:55 pm
I started doing the machine work on my engine for the Luv this week, this is what i've completed so far.
PostPosted: Sat Mar 31, 2012 4:31 am
PostPosted: Sat Mar 31, 2012 9:30 am
Late model roller cam 1 pc block and torque plate . Looks good .
PostPosted: Sun Apr 01, 2012 7:18 pm
Did some clearancing work for the H-beam rods
PostPosted: Sun Apr 01, 2012 7:21 pm
I'm using the late model block because of the 1-piece rear seal, but im going to be running a mechanical flat tappet for a cam instead of a hyd. roller
PostPosted: Mon Apr 15, 2013 10:57 pm
I'm jumping ahead a little bit but here's the finished project
PostPosted: Mon Apr 15, 2013 11:52 pm
I think you jumped a little ahead of the pictures. 8O
PostPosted: Tue Apr 16, 2013 12:38 pm
I will never run a flat tappet cam again . Ever . Nice work though .
PostPosted: Mon May 20, 2013 8:59 pm
pics wouldn't upload
PostPosted: Mon May 20, 2013 9:01 pm
heres a crappy pic
PostPosted: Tue Mar 11, 2014 5:20 pm
Yep flat tappet cams suck. Just wait till one goes flat and destroys your perfectly good engine. Spend a little for a roller it will be cheap in the long run.
PostPosted: Fri Mar 14, 2014 12:12 pm
That thing looks great! What tranny are you going with? And what are you using for pistons?
I would go roller if at all possible, cut down every bit of friction you can. may not be a lot but that may net a couple hp on its own.
