It is currently Sat Jul 11, 2026 9:59 pm
PostPosted: Fri Apr 12, 2013 7:23 pm
I have a strange situation going on with my truck. I have lots of oil coming out of my filter on the valve cover. ( not the pcv valve. It's the one that goes to air box).
I have ruled out the obvious problems, I think. Here is what I have done.
Changed the pcv valve
Compression test. 150 lbs on every cylinder
Checked for blow by. I have none.
Had Cat. Conv. Checked. They are bad, but probably not clogged.
I know there are many helpful mechanics on here, that's why I'm posting this question. I thought it might be clogged drainbacks?
Any help would be greatly appreciated. Thanks in advance!!
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Sun Apr 14, 2013 4:44 pm
With the engine running, pull the pcv/hose from the valve cover. With your thumb over the end there should be a strong suction. Also there should be very little smoke coming from the valve cover (blowby).
If nothing found there I would remove the valve cover and look for a missing baffle inside that keeps oil from the valve lifters from splashing up into the pcv/hose assembley.
PostPosted: Mon Apr 15, 2013 8:17 pm
I may have found the problem. There is soooo much oil soaked on everything, it may be a day or so till I find out.
I had bought a generic valve cover breather from Auto Zone. I think it was the wrong kind because the "valve" that was in the bottom of it seemed like it was wrong. I replaced it with another one that I think will work right. Oil seemed a lot less, but it was still leaking. I will take off the pcv hose and check for suction in the morning. Thanks you very much egg!!
Users browsing this forum: Majestic-12 [Bot] and 16 guests
