It is currently Wed Dec 17, 2025 9:01 am
 Post subject: Gas tank fill tube hose?
PostPosted: Sun Mar 31, 2013 3:08 pm
I was hoping to get my bed back on this weekend but am having trouble finding the relacement filler tube hose for the tank. I thought this would be an easy find but I am 4 stores down and nowhere to go. I even hit the industrial hardware store with no luck. Its is a short hose on a 72 and somewhere around 1.25" ID. I thought about some of that clear vinyl tubing but don't know how it would hold up.
Anyone know where to get something that will work?
PostPosted: Mon Apr 01, 2013 12:08 am
get bulk radiator hose.They use it for semis and tractors.
PostPosted: Mon Apr 01, 2013 10:05 am
Thanks for the tip, I am on a quest this week to find something that will work.
PostPosted: Mon Apr 01, 2013 6:15 pm
I got a straight hose when I put my bed on, the bend in the hose is pretty sharp for that big a hose. I was thinking a hose clamp to smoosh the kink. The only problem is I can't press the trigger very hard or use the hold down at the pump. Air can't get past the gas in the hose and the pump stops :x Let us know what you figure out for sure
1980 LUV 4wd 1.8, 31's, 3" body lift, weber 32/36, header, fakemaster, project in progress
1989 Isuzu Pickup 4wd 2.6, 2.3 head, weber 38, header, flowmaster, 31's, DD/light wheeler
1989 Camry, the race car
1968 Ford Fairlane Fastback, next in line
PostPosted: Mon Apr 01, 2013 8:10 pm
you should be able to pick it up at a NAPA or other parts store that carries stuff for semis.Just call your favorite parts tore.They should have it.Take your filler tube with to use as a guide.On mine I used like 6 or 8 inches.
PostPosted: Mon Apr 01, 2013 8:58 pm
I'll give Napa a try, it was the last place's suggestion too, but I was tired of driving all over by then.
PostPosted: Mon Apr 08, 2013 7:57 pm
Did you find some?
PostPosted: Mon Apr 08, 2013 8:46 pm
It was a learning experience. Napa had a hose that was close from a Ford for $38 and I passed on that. I then found O'riellys has bulk hose but not 1 3/4". I ended up going to the junk yard and finding a 78 longbed that still had a hose for $5. I can cut it to fit and it cleaned up real nice too.
If I had known what a hassle it is to find the right hose I would have removed the old one more carefully. 8O
PostPosted: Mon Apr 08, 2013 8:49 pm
That's the story of our lives with these trucks, always try to save anything coming apart.
