It is currently Mon May 25, 2026 3:29 am
 Post subject: coil over conversion
PostPosted: Thu Mar 28, 2013 1:54 am
hi people i need to convert my luv to coilover on the front .... what length shocks do i ned if i go ring/ pin or if i go ring / ring. also what spring rate from what ive worked out im thinking 230 to 250 pound , does that sound right..thanks in advance
 Post subject: Re: coil over conversion
PostPosted: Thu Mar 28, 2013 11:07 am
Do you have the stock engine or are you small blocked?
PostPosted: Sat Mar 30, 2013 9:28 pm
hi i have 2.8 liter 60 degree v6 with [img]turbo 700 tranny thanks
PostPosted: Sat Mar 30, 2013 9:35 pm
there should be a pic on my profile,,,,,adam davis 1974 model
