It is currently Wed May 27, 2026 2:02 am
 Post subject: seat swap
PostPosted: Mon Mar 04, 2013 9:22 pm
Hello all
Working on 1980 4X4, does anyone know of any seats (bench or buckets) out another truck will bolt in without a great deal modifications, any help would be nice. The stock seats are not so great!!!!
 Post subject: Re: seat swap
PostPosted: Tue Mar 05, 2013 7:34 am
I just found these BMW 325I seats that fit pretty good and the two outside holes in the floor lined up perfect with the seat brackets. There are only the holes on the inside to drill and the inside front rails will need a spacer as they are 1.5" above the floor. I was going to use some tubing as a spacer.
PostPosted: Tue Mar 05, 2013 7:37 am
i have a bench from a vw pickup fits well and the rails come close to stock holes. im going to mod the rails this weekend
PostPosted: Sat Mar 09, 2013 10:06 am
I put '76 toyota celica seats in my LUV. I did have to weld up a frame though. Thing I like the best is that you can put a tool box behind each seat and carry most of your stuff 'out of sight'.
PostPosted: Sat Mar 09, 2013 2:16 pm
I think pretty much any bucket seat should fit with the same amount of work, these are sportz seats from Sewfine, at the time they made a bracket with the luv hole pattern and I just had to drill the inside holes. If I get the interior out soon, I will take pictures of the mounts.
