It is currently Fri Jan 30, 2026 9:19 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jul 29, 2011 1:12 am
A swap that actually runs... Cool!
PostPosted: Fri Jul 29, 2011 5:43 pm
How did I miss this build. Looks awsome, refreshing to see something different.
[img][IMG]http://i962.photobucket.com/albums/ae108/FedMoore/thIMG_0358.jpg[/img][/img]
PostPosted: Wed Oct 26, 2011 9:25 am
ok so i added a methanol kit.......and man does it wake a turbo up. 18lbs boost popped the turbo 7k rpm and lost oil pressure. this winter project is to rebuild that sr20 :)
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Sat Dec 17, 2011 8:28 pm
how did you do the motor mounts on the sr20?
PostPosted: Fri Dec 30, 2011 3:50 am
you happen to have any pictures of where that shifter is located inside the truck? im thinking about an sr20 project... nice red top you got there...
PostPosted: Fri Dec 30, 2011 3:42 pm
@kertap - i removed all the stock mounting points and cleaned the rails. then put the motor and trans in the truck leveled and set it back as far as i could. luckily the stock sr20 pan cleared the center link. then i fabbed from the rails to the stock sr mounts with 1/8" plate. i used a ca18 i had to mock everything up and start fabbing the motor mounts
PostPosted: Fri Dec 30, 2011 3:44 pm
@jgilk1 - the shifter moved back about 6". i think i installed the shifter backwards so the bend went forward to clear the bench seat. i now have a short shifter and 180sx bucket seats
PostPosted: Thu Jan 12, 2012 9:22 pm
hey since you said you were pulling the motor for a rebuild you want to get some more pictures of the engine bay? more specifically the mounts you fabed up?
Thanks in advance
PostPosted: Fri Jan 13, 2012 3:39 pm
Are you still looking for an early grille?
PostPosted: Fri Jan 20, 2012 10:15 pm
so it was fairl simple to get the motor in?thinkin about doing this to my other luv haha not trying to steal your idea or make you made just know how much those motors can take :lol:
PostPosted: Thu Feb 23, 2012 4:04 pm
x2 on the pics haha starting my sr20 build :lol:
PostPosted: Sun Jul 01, 2012 3:31 am
Hey mate just wondering how the ute is going. And was just wondering if u can help me out with a few questions. I was wondering how u went with the fitting of gear box and what u did for diff. If it would be possible if u could snap a few photos for me of all mounts and any fab work u did to shimmy in the red rocket. I have been undecided about which jap motor to put in. And i had a sr in the past so thought be good idea. Thumbs up for ur work mate hope its going all good. Thanks
PostPosted: Sun Aug 26, 2012 8:53 am
utah has been good. been busy. these roads are so open out here. its pretty cool to just cruise.
i got the methanol injector worked out now its pretty smooth. id be happy to answer any questions.
i'm still commuting the truck so my boy saverd up and got a 70 bug. ive been wrapped up with thatbody off build now if i can only find an ej20t for his bug :lol:
PostPosted: Wed Jan 23, 2013 9:59 am
8500rpm 14lbs boost w/ methanol injection
goo0d thing i bought another block when the deal came around. just a reminder to use arp rod bolts when your gonna goof around
PostPosted: Thu Jan 31, 2013 9:59 am
PostPosted: Thu Jan 31, 2013 1:59 pm
Uh-Oh... :(
PostPosted: Fri Mar 01, 2013 2:06 am
How hard was it to wire everything up? And mount the engine?
I know you've posted pictures, but I'm honestly having a hard time seeing the brackets and such.
Thanks.
PostPosted: Fri Mar 01, 2013 4:55 am
not hard. cut the luv engine mounts off. set the motor in place with wood underneath the engine i used the shifter machined block on the tranny to level side to side. i used cardboard to make a template for the engine mounts then transferred to 1/8" plate. i also had to fab a tranny mount. this is a cool and easy swap
the wiring was abit tricky. i used relays to run this harness separate from the luv's chassis harness. you dont need to chop up the sr20 harness just tie into the battery connection portion. Image
PostPosted: Fri Mar 01, 2013 11:01 pm
Good information to me. I will need to do this on my 13b FD swap.
My names Trevor BTW. ;)
PostPosted: Wed Mar 06, 2013 9:09 am
Badass truck, what wheels are those? i dig them
If the system fucks you. You fuck it back!
Users browsing this forum: Bing [Bot] and 14 guests
