It is currently Fri Apr 10, 2026 9:37 am
 Post subject: Pertronix dist. upgrade
PostPosted: Sat Sep 29, 2012 9:00 pm
Has anyone bought one of these? Experiences? Advice? I've notice since I originally wanted to buy one it's gone up $10 in price. I should get the Nippondenso distributor for my '77 correct? Thanks fellers.
PostPosted: Sat Sep 29, 2012 11:56 pm
Not for a LUV, but I have upgraded several GM distributors over the years. I saw an ad recently where they have one that has a rev limiter built in. But sorta looks like a pain to take the cap off to adjust it...
PostPosted: Sun Sep 30, 2012 1:53 am
i have seen a few peopel on the forum talking about them working well. i got a good deal on an 85 pup distributor for electronic ignition so went that route but i have heard good things about pertronix
PostPosted: Sun Sep 30, 2012 12:46 pm
Recommended. It installs very easily, and there's no more adjusting points, ever! I haven't touched my distributor since.
PostPosted: Thu Oct 11, 2012 5:33 pm
Ordered my Pertronix today, hopefully I got the right one... For my '77, probably all good. Anyway, No more points here I come! I'll probably keep an extra set around just in case, for the anticipation of the Impending EMP :) swap it out and drive around all Mad Max n stuff.
PostPosted: Sun Oct 21, 2012 7:59 am
Woo, finally got my pertronix in the mail. is it bad that it says its for a toyota 4 cyl? Any protips on how I install this bad boy? remove the oblong rotator? remove the condenser? gap to set? Man, I'm still so new at this... :? Sometimes I wonder why i even own vehicles...
PostPosted: Tue Oct 23, 2012 2:59 pm
Go to Youtube and look up Pertronix. I did the other night, and one of the first things in there was how to set them up. But Basically, You take out the points and condes. Bolt the Pertronix back in its place (run your wires first from the inside to the outside). Use the plastic gap gauge set it....tighten bolts. connect Neg. and Pos. on your coil. start it up and drive away. Eveything I have read on them is stating they're Plug an Play. There isn't any need to mess with your timing (unless you have messed with it already and is running like crap). Let us know how its working for you. I'm buying one tomorrow. :)
My House Is Guarded By A Shotgun 3 Days A Week. Guess Which Days.
PostPosted: Tue Oct 23, 2012 4:04 pm
While it may run without re-timing, I wouldn't go as far as saying there isn't any need to mess with it. I certainly found room for improvement after I switched over. I believe there is a slight registration difference between the standard points and the Pertronix kit, necessitating at least a SLIGHT twist. It's worth the extra 2 or 3mpg, I think.
This was just my experience. Anybody else care to chime in?
PostPosted: Tue Oct 23, 2012 6:05 pm
Ok, I was wrong. Thanks for letting me know whats up. I was just going off of the youtube videos.
PostPosted: Thu Oct 25, 2012 11:43 pm
woof, haven't been able to get to it just yet, I'll youtube that linky for sure, I've been a little pre occupied with another project of mine this week and I've got a deadline to get it all done in. :P Dad wants his garage back. I want in to my house... short sales blow goats btw.
anyway, this is my current project... http://www.redpepperracing.com/forums/i ... =54428&hl= off topic for sure but I feel the need to explain myself. :D
and I figure if I do this right I should be in good shape to work on my LUV when I get in to my OWN garage :D DDDD
PostPosted: Sun Oct 28, 2012 4:05 pm
The REX looks kickin! you are matticulas.
PostPosted: Wed Jan 30, 2013 10:40 pm
Just got my Pertronix kit in the mail. Ordered the 1643 kit from Retro Rockets. The ring has a part number 1641. Has anyone ordered the 1643 kit. The tag on the box is for an Ignitor Toyota 4 cyl. smaller Cam S. Am.
76 LUV
PostPosted: Sat Feb 09, 2013 12:09 am
just orderd the same. How was your install? Impressions?
I assume Toyota used the same nippondenso dizzy. The Pertronix catalog specifies 1643 for the 78-80 LUV
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Tue Feb 12, 2013 4:06 pm
I haven't had a chance to work on my truck. I want to make sure that the magnetic sleeve is the right one. I sent an e-mail to Pertronix and waiting for a response. Eyesore what part number was on your magnetic sleeve.
76 LUV
PostPosted: Tue Feb 12, 2013 6:10 pm
It is still in the mail. I expect it this week. I will post what I find.
PostPosted: Tue Feb 19, 2013 4:45 pm
Got my pertronix on Monday. Mine also has the 1641 ring. Have you heard back from them yet?
Is this correct for our LUVs? can anyone else chime in? Have you used this ring, or do I need to buy yet another part?
PostPosted: Mon Mar 04, 2013 12:23 am
OK, finally had warm weather and was able to get to the LUV today.
Good news! The 1641 ring works fine. Installation was quick and easy.
I did need to re-time it though. It would barely even start and run enough to get the timing light on it, but once we did, it was a simple matter of dialing it in. Running sweet!
PostPosted: Thu Mar 14, 2013 7:21 pm
any hints on the gap you used? etc? some place I can start so I'm not trying so hard to get dial in the timing? ^_^
PostPosted: Fri Mar 15, 2013 5:35 pm
Well, the gap (spark plugs) were set at .044
But I think you're asking what the timing is set at. Not sure where we started at, but ended at 12 degrees advanced.
Hope that helps. Other than the timing it was a very simple job. Good luck!
PostPosted: Sat Jul 06, 2013 7:09 pm
Hey guys. I also wanted to upgrade to pertronix and get away from my points. I got a '78 stock. rebuild the engine myself. its sweet. but can't find a weber for a good price. so gotta wait on that. but my serials are worn off of my dizzy. and don't know which set up I need. can anyone enlighten me please that has done the upgrade or purchased the correct installment? what do I need exactly for the correct upgrade? About how much am I lookin at for the whole shibang? thank u in advance for info guys.
Users browsing this forum: No registered users and 98 guests
