It is currently Sun Jun 07, 2026 2:36 pm
PostPosted: Sun Feb 03, 2013 6:15 pm
Can someone give me the torque specs for the shackle bolts and the spring bolts please. My Haynes says 130lbs for 72-75 and then 95 lbs for 76-77 :econfused this seems awfully tight. I torqued one side and it's pretty stiff. I have an FSM but it's for an 82 and doesn't even have the specs at all :econfused :? It's a 1980 4wd, thnks
1980 LUV 4wd 1.8, 31's, 3" body lift, weber 32/36, header, fakemaster, project in progress
1989 Isuzu Pickup 4wd 2.6, 2.3 head, weber 38, header, flowmaster, 31's, DD/light wheeler
1989 Camry, the race car
1968 Ford Fairlane Fastback, next in line
PostPosted: Tue Feb 05, 2013 9:37 am
From a 1980 FSM: 70 ft lbs, both ends
70 ft lbs = 95 N-m
PostPosted: Tue Feb 05, 2013 2:03 pm
Thank you sir! It doesn't surprise me that haynes mixed up the newton meters and ft. lbs :roll:
