It is currently Fri Dec 19, 2025 10:02 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: 350
PostPosted: Wed Jan 23, 2013 6:26 pm
The s10 rear is barely wider than stock. It's 5 lug though.
PostPosted: Wed Jan 23, 2013 8:33 pm
Is it much stronger ? And I can get one but it has welded spiders in it.do to think its worth swapping with the welded gears?
I Dont Need Sex Life Fucks Me Whenever It Can.
PostPosted: Wed Jan 23, 2013 11:40 pm
Street driven, I would pass on the welded spiders. Also, make sure the s10 donor is a two wheel drive as the 4x4's are wider...
PostPosted: Wed Jan 30, 2013 1:25 pm
Okay spotted a 350 and pickin it up this weekend. It also has a 700 r4 attached.i need a way to get it into the back of my truck, and suggestions. No cherry picker or front end loader. Redneck is fine as long as it works lol.
PostPosted: Wed Jan 30, 2013 4:41 pm
if redneck is fine pick up a case of beer and recruit a few buddies :lol:
the 700r4 should be easy enough to get in on its own, a small block is what 550lbs? something like that i would want to get it up off the ground maybe set on a spare wheel/tire behind the tailgate and then lift the rest of the way into the bed.
maybe try to track down a used picker from craigslist i got my engine stand for $25
PostPosted: Wed Jan 30, 2013 4:45 pm
Yea I thought about that I can get tranny easy but engine.... Lol I thought get it on a pallet and I have ramps and ratchet it into the back lol.
PostPosted: Wed Jan 30, 2013 5:55 pm
thats not a bad idea actually..
hell throw it in a skateboard and a 2x12 :lol:
PostPosted: Wed Jan 30, 2013 8:29 pm
You can rent a cherry picker pretty cheap.
PostPosted: Wed Jan 30, 2013 8:31 pm
Where at?
PostPosted: Wed Jan 30, 2013 9:24 pm
Most equipment rental places have them. United Rentals has them. I don't know where in Oklahoma you are, so I can't really help. You're gonna need one to set the motor in the truck for sure. Just google equipment rentals and your city and state.
Harbor Freight sells them for $150. http://www.harborfreight.com/1-ton-capa ... D%3D%0D%0A
I've got one from Harbor Freight and it's been good to me.
PostPosted: Thu Jan 31, 2013 5:52 am
This ^^^^^^^^ ......Rent the one with wheels on it that can be towed behind your truck .
PostPosted: Thu Feb 14, 2013 9:52 am
Got 2 350 4 bolt mains and a 307 lol now behind the rebuild process lol
PostPosted: Wed May 01, 2013 2:23 pm
Okay pretty close on the engine rebuild. I guess this is the time to be proud of what I do for a living lol (machinist). But I got it bored .040 got forged pistons I think stock crank. Chevy 350 crate motor heads that I ported and gasket matched myself, I have a couple of intakes and don't know which to use. I have a edlebrock torker or a crate bowtie intake. I want to run on the street and put the nitrous to it. Maby a 200 shot. Which intake u guys think? Sorry for the novel.
