It is currently Mon May 25, 2026 10:07 pm
PostPosted: Wed Jan 09, 2013 5:33 pm
I'm getting a free 305/700R4, so it's going in the LUV. It's a 92 out of a van, and has throttle body injection. I want to convert it to carburetor and was curious to know if anybody knows which intake, carb, fuel pump ect it takes to make the switch.
PostPosted: Thu Jan 10, 2013 9:43 am
You should be able to use any standard small block chevy intake/carb combo for this swap. You can put a stock mechanical pump on this also. It should be a pretty straight forward swap. Only issues I see will be in things like linkages for the throttle and transmission kickdown.
PostPosted: Thu Jan 10, 2013 10:31 am
Center holes on the intake to head mounts need slotting on some intakes due to a slightly different angle. No biggie. If you are getting the complete set up I say install the tbi...
PostPosted: Thu Jan 10, 2013 5:12 pm
I want to stay away from the tbi or tpi because I know a little about carbs and also want to go without computer and all the wiring. I plan on doing the installation of the carb ect while it's still in the van for a smoother install into the LUV.
