It is currently Sun Jun 07, 2026 12:14 pm
 Post subject: exhaust header ?
PostPosted: Mon Jan 07, 2013 1:04 am
my exhaust header has a crack in it what is the best way to fix it without replacing it
 Post subject: Re: exhaust header ?
PostPosted: Mon Jan 07, 2013 10:35 am
Have a muffler shop look at it and see if it can be welded up.
PostPosted: Mon Jan 07, 2013 10:42 am
i have a tig and a mig welder what one should i use and does anybody what it would cost me for a header
PostPosted: Mon Jan 07, 2013 1:10 pm
I prefer TIG. Is this a header or manifold?
PostPosted: Mon Jan 07, 2013 1:16 pm
its the header also what do i need to test my gas tank sending unit
PostPosted: Mon Jan 07, 2013 5:22 pm
Ground the wire going to it, if the gauge goes to full then everything from the wire to the gauge works. If the sending unit is out of the tank use a ohm meter.
