It is currently Fri May 01, 2026 4:48 pm
PostPosted: Sun Dec 07, 2003 11:00 pm
I have a 82 s 10 with a 1.9 gas engine, 4 sp and 81 2.2 diesel engine from a LUV. I am looking for information on a trasmissions. Will the tramsmission from the 1.9 bolt up to the 2.2 diesel? If not are there any common transmissions that will bolt up?
PostPosted: Mon Dec 08, 2003 2:07 pm
it might bolt up, not exactly sure though. 82-85 s10s had the same 2.2l diesel engines as the luv, if i'm not mistaken
PostPosted: Tue Dec 09, 2003 11:08 am
I have a 1985 S-10 with the 2.2L izusu diesel engine in stock form. When the truck hit 190,000 5th gear went sour. I bought a 5 speed transmission from a junkyard that came out of a stock 4 banger S-10, to swap in. I thought it would bolt up.....It didn't The bell housing is complety different, as well as the input shaft. So what I did was change the guts over to my stock diesel transmission (keep in mind all that I need to change was the gear)
So in short look for a transmission out of a 1981-82 Luv, 1982-1985 S-10(5speed), 1983-1986 Pup, or I think out of a trooper that has the diesel engine will work.
Having a luv with the 4 speed(4x4) and the S-10 with the five speed(2x4) I would recommend that you find a 5 speed since the overdrive helps the engine run better. I am trying to find information on swapping my two transmissions around.
1981 Chevy LUV 4x4 2.2L Diesel 4 Speed Selling out moving over to VW TDIs.
PostPosted: Sat Dec 13, 2003 9:29 pm
I dont think a 5speed out of a trooper will work. The motors they put in them (unless its an early one whith a 1.9L or 1.8L oid a diesel) the bell housing is diferent i have been told. You will probly have to find an isuzu PUP whiht the small 4bangers or a luv to donate a tranny for ya.
PostPosted: Mon Dec 15, 2003 11:09 am
I am sorry I should have been more clear.
So in short look for a transmission out of a 1981-82 DIESEL Luv, 1982-1985 DIESEL S-10(5speed), 1983-1986 DIESEL Pup, or I think out of a DIESEL trooper.
I believe any Isuzu 5 speed transmission will work as long as it came from an Isuzu 2.2L diesel truck including troopers.
This is a quote from a Diesel Trooper that I was going to buy
"It is the 2.2 turbo, the only diesel that isuzu sold here in the US.
It is a 5 speed with overdrive, again, the only way it was sold. I get
about 25 to 30 mpg."
PostPosted: Mon Dec 15, 2003 9:58 pm
man i realy whish we would get more diesels over here. Isuzu made an awsome diesel for the UK, 2.5L. It was loud as hell but vary reliable and stuff. I just wish we could get all the motors over here... :?
