It is currently Fri Jan 30, 2026 8:50 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Nov 13, 2012 8:22 pm
Wicked Mayhem wrote:
i like those super lights on there.
Plans on getting rid of some of that wheel gap?
Ironheaded small block first then torsion bar adjustment .
PostPosted: Wed Nov 14, 2012 10:07 am
LSX LUV Owner
Cool. On my old luv I ran 2" block in the rear and cranked down the torsion bars up front on 165r's to have a little rake. Didn't ride too bad. Not sure how it would hook up at the track lol
PostPosted: Fri Nov 16, 2012 4:40 am
Dis assembled the 9 inch today washed it out and bought new ends . Ordered new Strange axles and dropped housing off at the race car shop to be narrowed . Gear is already set up with a spool and 3.60 gear . Rebuilt truck drums will be on the ends .
PostPosted: Fri Nov 16, 2012 1:36 pm
More cleaning . The broken air shockes were removed and the new/old ones from the Yellow truck were installed . All the poly tubing from air shocks removed . The rear section of the wiring harness was a mess . These trucks have the seperate turn signal brake light and require a converter box for trailer lights . Looked like there was 15 splices back there . I had the tail light harness off a 78' a buddy of mine parted out that was a Texas A&M campus maintience truck ( wornout ) . It was prefect so in it went . Both the side marker lights in the rear were not working due to broken wires . Had replacements as everytime i find one of these trucks i buy the lenses . Actually got the wiring cleaned up and working . Thinking the 4 cylinder might run . I found a good home for the motor here in Houston/Tomball . A father son restoration of a stock 1978 with a automatic and the parts will be helping there project .
Ordered a new oil pan , valve covers , breathers , air cleaner , roller rockers . This should be the last of the big stuff pending the radiator .
PostPosted: Fri Nov 16, 2012 5:27 pm
LSX LUV Owner
Truckin along.
Do the lights on the fenders alternate with the blinkers in the bumpers from the factory? Or are they just side marker lights? I am finally going to hook those up but what it like factory
PostPosted: Fri Nov 16, 2012 5:54 pm
mine are just markers
PostPosted: Fri Nov 16, 2012 6:12 pm
LSX LUV Owner
oh ok. with my headlight switch, when my headlights are on, my running lights are not on. is that how LUV's are?
PostPosted: Fri Nov 16, 2012 8:11 pm
No, they should be on all the time.
PostPosted: Fri Nov 16, 2012 8:50 pm
They should be on if the headlight switch is halfway out or all the way out.
PostPosted: Fri Nov 16, 2012 9:01 pm
LSX LUV Owner
10-4. Thanks for the info. Need to find out about redoing some wiring then.
Done cluttering your thread Raland :D
PostPosted: Thu Nov 22, 2012 1:16 pm
Got a little more done on the drivetrain this week . Rocker arms are on and valves adjusted . The oil pan was from a caprice or roadmaster with the sensor in the pan and i couldnt get it to stop leaking . i replaced it with a new truck pan . i am waiting on the valve covers and breathers to come in and it should be close .
Also got the housing narrowed and the axles came in . The bearings are not correct , so i will have to wait for them to come in or buy them local . The axles should have come assembled and ready to install . I dont have a press so i have no idea what im going to do there . I double flaired the factory brake line with a standard 3/16 end to allow the use of an F150 brake flex hose .
PostPosted: Sun Nov 25, 2012 9:28 am
Wrapping up the motor .
PostPosted: Mon Nov 26, 2012 5:31 pm
Got this far today .
PostPosted: Mon Nov 26, 2012 11:22 pm
Kewl!
PostPosted: Tue Nov 27, 2012 7:54 am
LSX LUV Owner
Looking good.
PostPosted: Thu Nov 29, 2012 5:26 pm
Not very romantic , but all the lights and signals now work except passengerside rear side marker . The wires are off it . I will solder it back up and re install it . The left turn signal indicator in the dash is bad so i will get it fixed , Got the horns working . Stock motor is locked up solid . More clean up and 1/0 battary cables built .
PostPosted: Sun Dec 02, 2012 7:15 pm
Got a bit farther along . The motor mounts were used and cut out of another truck . A budy of mines son Shawn is in metal shop class and he used the motor mounts as a project in metal shop . I got the hood off and more wiring done . All the lights are burning now . most of the stock motor is disconnected and ready to be pulled . Wife had me doing yard work most of the weekend , so no huge steps , but it iscoming along . Stock motor which is locked up about to come out .
All the key player having a meeting before moving in .
PostPosted: Sun Dec 02, 2012 8:10 pm
LSX LUV Owner
Moving right along. Is the Ac system complete? Are you going to keep it?
PostPosted: Sun Dec 02, 2012 8:36 pm
Yes and yes . Alan grove makes an a/c bracket that bolts into the fuel pump boss to mount it really close to factory . Gonna change the expansion valve and dryer and convert to 134A .
PostPosted: Sun Dec 02, 2012 8:41 pm
LSX LUV Owner
Cool. Will make for a real nice cruiser with Ac. Can't wait to put Ac on my truck.
