It is currently Fri Mar 27, 2026 10:55 pm
 Post subject: Not Getting Fuel!
PostPosted: Sun Nov 18, 2012 11:20 am
Ok so my fuel pump is working but isnt drawing any fuel from the tank. no blocks that i can find. Any ideas? Plz help
 Post subject: Re: Not Getting Fuel!
PostPosted: Sun Nov 18, 2012 7:46 pm
Check the fuel filters.If there is rust in the tank it will block the pick up tube.Check to see if you have fuel at the carb by looking at the sight bowl.
PostPosted: Sun Nov 18, 2012 9:55 pm
Try blowing the line backwards with compressed air----low pressure. If you can hook up on the tank side of the fuel pump line near the left rear wheel. Any rust etc. collected there might be removed, at least temporarily. I've heard that sometimes the tank cap can become a restriction too.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 43 guests
