It is currently Sun Jun 07, 2026 12:27 pm
PostPosted: Tue Nov 13, 2012 4:27 pm
I'm having trouble keeping my water pump tight it keeps coming loose anybody knows why this is happening???
PostPosted: Tue Nov 13, 2012 4:58 pm
Try new hardwear and loctight if needed. I would guess the nuts/bolts are warn and streaching.
PostPosted: Tue Nov 13, 2012 7:18 pm
I'm with you. I've ran into bolts coming loose do to vibration. RTV works to if he dont have loctight on hand.
PostPosted: Wed Nov 14, 2012 6:13 am
Well you need to change the bolts because they are now loose maybe you over tight them so their locks are smashed. So change the bolts. If you still face the problem then use some locks which can hold the bolts on their place.
I am a spammer for car accessories gold coast
PostPosted: Wed Nov 14, 2012 8:56 pm
Over-tight belt or bad bearing causing problems perhaps??
